truck bed gas filler hose question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2011, 08:46 PM
moved the tank under the new bed on a 51' chevy but fitting on the tank is a different size than the bed filler. does any one know where you can buy 1 7/8" hose reduced to 1 1/2" hose?
Old 09-06-2011, 10:30 PM
dinger's Avatar
This probably won't work but is worth a try. Can you take a 1 1/2 inch piece of hose, cut off an inch or so, put it on the filler and then put the 1 7/8 hose over it, clamp it down and be ok?
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 09-07-2011, 11:59 AM
StudebakerDean
graingers for hoses
Ive had great luck with www.graingers.com for hoses of all types or where ot find them.
Old 09-10-2011, 10:07 AM
SSedan64's Avatar
How about a Galvanized exhaust pipe reducer/adapter in the middle of 2 sizes of Hose?
Old 09-10-2011, 12:27 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
H'mmm would it be possible or reasonable to change the filler pipe???
Sam
fill the old gas filler hole in truck body Studedean Body - Exterior 2 07-14-2011 12:56 PM
filler neck hose for main gas tank Arillious Engine 5 12-14-2008 03:45 AM
Stepping down a fuel filler hose 2.25" to 1.5" wyomingclimber Engine 11 02-13-2008 05:01 PM
Fuel filler hose for 1977 Chevy C20 Terje Engine 0 07-18-2004 09:52 PM
FUEL FILLER for street rod truck OLEB97 Hotrodders' Lounge 3 06-21-2002 07:09 PM
