truck crate engine, older intake? pattern? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2010, 02:49 AM
fast68's Avatar
likes chevy trucks & boobies
10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal
im thinking about acquiring one of these engines that only has 75k miles on it, someone wants me to trade me a 700r4 tranny i have, for it.
will any of the common stock GM casting 4bbl intakes fit on these engines? same bolt pattern ?
or common 87up tbi stock intake?
would the heads on this engine be the old intake pattern style?
or ?
ive totally lost track on when the heads and intake bolt patterns changed, and for which engines.
werent two intake bolts done away with or something? around 1995?
or did these crate engines keep the older intake pattern after 1995?
i also read somewhere that these crate replacement engines were not actually vortec? so must be older style heads then?
thanks
Old 09-11-2010, 03:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
or ?
thanks
The 880 block was used w/Vortec heads. I believe they could also have been used w/non- Vortec heads originally. So, to know for sure you need the casting number of the heads, period.
There's no way to say w/any certainty what the bolt pattern on the heads will be, w/o knowing if they're the '96-up 062 or 906 Vortec heads or '95- back (there might have been some crossover, I don't know) swirl port TBI heads, or even something else altogether.
You know the Vortec heads require a tall port intake w/the Vortec-only bolt pattern. No other pre-Vortec intake will fit w/o extensive work.
The other likely option is the "straight" center bolt heads, like used w/the TBI, etc.. Intakes from '55-up can be used if the center bolt holes of the intake are elongated and washers w/the correct angle on them are used to hold down the intake. There are aftermarket intakes for all of the different head types, obviously.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
GM 5.7L crate engine suffix codes SCRUBBY Engine 2 11-30-2009 04:36 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
302 chevy engine mess NaythanOldskool Engine 17 12-18-2008 12:04 AM
changeing a TBI with older Intake & 4b Carb WILDBRONCO4 Engine 2 10-10-2003 03:36 PM
