Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Truck headers and exhaust configuration
Old 04-30-2012, 05:15 AM
75gmck25 75gmck25 is offline
Its mostly just personal preference. The real key is to try and put as few bends as possible, and make the bend radius as wide as you can. With a truck you usually have plenty of space to work with.
Its a little louder in the cab if it exits in front of the tires and you will get more exhaust residue on the side of the truck. I think its legal in most states, but its not done very often.
A straight rear exit is harder to route around the spare tire if its still in the back under the truck. A side exit may be more convenient if you use it as a work truck, since it routes the exhaust away from the tailgate where you are trying to hook up a trailer or load something into the bed.
Bruce
