truck? rear end ID help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2011, 09:53 PM
Hi all,
I have this 5 lug 12bolt rear end in an 66 chevy suburban that I bought and wondering if anyone can help me identify it. This is the code stamped on the axle tube RNA N294 2e. I have searched for a long while with no luck , any info would be very helpful.
Thanks!
Old 05-24-2011, 08:38 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
the format suggests 71 and later axle, but the R doesn't help. That's the factory where it was built and there is no "R" plant.
Old 05-26-2011, 10:53 PM
Thanks curtis73, I appreciate that. Guess I need to put on my glasses and inspect the stamping a bit closer...
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 05:17 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
new rear end for 48 truck,please HELP!!! FireRodder48 Transmission - Rearend 7 07-29-2004 01:04 PM
gm truck rear end rhett Transmission - Rearend 6 06-18-2003 04:11 PM
Truck Rear End FiefSS Transmission - Rearend 1 02-13-2003 07:19 PM
