truck shaking in 4th gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2010, 08:27 AM
Hello, I have a 78 400m when I shift into 4th gear the truck kinda shakes in the motor. especially underload. 1st and 2nd gear no problem but when I get into 3rd going into 4th the shaking starts. It only happens when I first go into the gear after that it smooths out. Kinda fells like when you shift into a gear to early then smooths out. Thanks for the help
Old 10-27-2010, 06:10 PM
check your motor mounts and transmission tail mount at the cross member.
Old 10-27-2010, 06:16 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Could be the clutch/pressure plate also.
Cole
T-400 Speedometer gear changes Torque454 Transmission - Rearend 2 08-09-2010 12:45 PM
truck "diesels" when i shut if off while in gear???? badk5 Engine 4 09-11-2005 01:48 AM
Towing in 3rd with a 4th gear lock up kit in 700r4 wed68 Transmission - Rearend 4 03-25-2005 01:34 PM
Truck 12 bolt gear ratios SAATR Transmission - Rearend 4 01-15-2004 12:52 PM
1978 chevy truck rear end gear ratio? gpeak Transmission - Rearend 2 11-26-2003 12:54 AM
