Truck shutting down
I have a 95 ford f350 with a 7.3. they other day going home it shut down on me. After letting it sit for a min. it started back up and moved another 100 ft and shut down again. This went on for about a half hour before it just shut off as soon as it started. I got a new cam sensor and installed it but it wouldn't start. I put the old one back in and it started right up soIdrove it for about forty minutes and this started tohappen all over again. Is there such a thing as a bad sensor or do you think it may be the ipr valve shutting me down. The other thing is that I can start my truck without the key sometimes, do you think it might be the key switch and when I floor the truck it will bog down and shift hard every once in a while. Any suggestions would be great. Thanks 95Marine
