Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Truck stalls when put in gear?
Old 08-04-2012, 04:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by gowser View Post
I installed a 350TH from 1982 Capric Classic behind 1968-327 Chevy. My problem is at 1000rpms the truck stalls when put in gear. When I increase the RPMS to keep it running the truck jumps ahead when put into gear. As far as I know the torque converter is original. Lots of help needed thanks GOWSER.
Sort the timing out first. This is especially important if the engine has a performance cam in it because if the initial timing isn't high enough, the carb primaries will be opened too far to get it to idle and that can cause the problems you're describing.
The Following User Says Thank You to cobalt327 For This Useful Post:
gowser (08-05-2012)
