truck trans in car - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-15-2007, 08:20 PM
Originally Posted by baddbob
A weaker version of the toploader can be found in older econoline vans and it'll hold up reasonable well if common sense is used, same externally as the toploaders behind all the performance v8's of the late 60's and early 70's. A friend of mine uses these all the time. Bob
how common or uncommon are these?
  #17 (permalink)
Old 02-15-2007, 09:08 PM
fairly common, look for a 4 speed in the econoline vans from the early 70's to late 70's
Trans for 500+ HP SBC in a 3500 lb car nastynova Transmission - Rearend 11 12-05-2006 11:08 AM
SBC truck block with car oil pan? curtis73 Engine 9 10-09-2006 04:06 PM
It's all in the details... Nightfire Hotrodders' Lounge 18 09-16-2006 09:53 PM
Finally got the car home. Fade to Black Hotrodders' Lounge 5 07-15-2004 10:13 AM
454 Truck block different than Car Blocks? zachscc Engine 11 12-19-2002 01:27 PM
