truck troubles
hey guys srry to keep bugging you all the time lol but i need help with the engine on my 80 gmc half ton 4wd with a 350 it just isnt as snappy as i think it should be and ive been told that my kick down cable isnt hooked up but idk and well heres the problem when u step on it while cruising it spits once then takes off and idk whats going on please help
truck troubles
yes i did i gave it a full tune up of everything plugs wires oil air filter oil filter the works and it still just lags a little bit or unless u stab the go pedal to the floor it spits and then accelerates i was told it might be the carb is dirty and to dump a bottle of sea foam down it and run it through
truck troubles
k how would i tell if its working or not
One way is to connect a timing light and remove/apply vacuum to the advance can while watching the timing mark with light,it should move at least 10º.
It is not uncommon for these to go bad. |
truck troubles
ok now where would i find the kick down cable to see if its hooked up that way i can down shift if i punch it to hop on the interstate
| 94 chevy truck runnin' like poo! | bluesmanjesse | Engine | 11 | 11-09-2006 02:54 PM |
| looking for a pic - the Navarro (?) families 68/69 chevy truck | lowROLLERchevy | Hotrodders' Lounge | 0 | 10-03-2006 03:24 AM |
| My new(used) truck | 1931 steve | Hotrodders' Lounge | 5 | 09-02-2006 11:54 AM |
| help identify truck | blackbeard | Suspension - Brakes - Steering | 2 | 01-25-2005 06:28 AM |
| Ebay Truck Headache | CrashFarmer2 | Hotrodders' Lounge | 8 | 09-06-2003 07:30 PM |
