Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Truck won't idle after carb rebuild
Old 06-20-2012, 01:29 PM
hauss667's Avatar
hauss667 hauss667 is offline
Knuckle color never lies
Last journal entry: gettin with the times
I tried moving the pump arm, it did make a difference in throttle response but to no avail. I did however notice that when I double checked for leaks some of the carb cleaner (I'm out of ether) pooled around cylinders 2 and 4 and was bubbling... I tried all the others thinking maybe it was just heat from the heads boiling it but none of the others did it... Have I found my deathly leak? I always assumed it would suck not blow if one of my intake runners were leaking
