Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Truck won't idle after carb rebuild
  #33 (permalink)
Old 06-29-2012, 10:07 AM
hauss667's Avatar
hauss667 hauss667 is offline
Knuckle color never lies
Last journal entry: gettin with the times
Now I'm not so sure I did. I checked everything new plugs and wires ignition control module is fine coil is good pickup coil is fine new condenser good compression, 0 vacuum leaks, base timing 10 btdc 36 with advance hooked up 5.5 psi at the carb, spark is blue... The only possible thing left is the carb. But everything was done per edelbrock specs .095 secondary jets .086 primary jets .065 x .052 rods and the orange step up springs. I mean theres not much more you can mess up in an afb...
