Truck won't idle after carb rebuild - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 06-29-2012, 02:25 PM
hauss667's Avatar
Knuckle color never lies
Last journal entry: gettin with the times
Thank you so much and I did use google and it gave me a bunch of gibberish about armani sunglasses lol but I'll give it another shot.
Should I just put the original jets and rods in for now or do you think a 625 is too big for a 305?
  #47 (permalink)
Old 06-29-2012, 02:34 PM
Banned
Id go one step leaner on the primary section of the rods still. You can measure them with a micrometer if you can't read them. My first carb was an edelbrock 1406, best carb to start with ever.
625 is not too large at all. I have a 1406 on my ford 2.3l right now, runs better than the 390cfm holley did.
  #48 (permalink)
Old 06-29-2012, 02:36 PM
hauss667's Avatar
So like I said I've never done this jetting deal (and probably never will again after this) but I found the rod specs, they're 70x47 whats the next step down from there?
  #49 (permalink)
Old 06-29-2012, 04:31 PM
hauss667's Avatar
So I cant get to a part store for a little while so i just put the carb back the way it was and it starts easier and throttle response is much better but it still doesn't want to idle. I have to start it and keep it running with the choke (it doesn't have one) is it normal for the engine to rev up when you close the choke partially? I've neve experienced this thats why I'm asking
  #50 (permalink)
Old 06-29-2012, 04:39 PM
Banned
Are all your unused ports on the carb properly plugged? You may still have a small vacuum leak. Do you have a vacuum gauge, adjust the idle feed screw for the top vacuum.
  #51 (permalink)
Old 06-29-2012, 04:49 PM
hauss667's Avatar
Yeah everything is plugged and I dont have any vacuum leaks that I can find, I didn't even pull the carb just took the top off and swapped everything back. I'm actually leaving shortly for the bank lol I'm in the process of buying anther vehicle, just a small commuter for work but I can mess with the vacuum some when I get back. Is the choke thing pointing towards a vacuum leak?
  #52 (permalink)
Old 06-29-2012, 04:59 PM
Banned
In this heat you shouldn't need a choke at all. Leave it open.
  #53 (permalink)
Old 06-29-2012, 05:13 PM
hauss667's Avatar
I didn't think so lol, but why would it only run when I choke it some?
  #54 (permalink)
Old 06-29-2012, 06:34 PM
Banned
Probably because its running lean. If your screws are al the way out then it means you either have a vac leak or crap in the carb.
  #55 (permalink)
Old 06-29-2012, 07:20 PM
hauss667's Avatar
The screws are at 2 1/2 turns
  #56 (permalink)
Old 06-29-2012, 08:29 PM
Banned
try adjusting then out a few more turns, a half turn each at a time. watch your vacuum gauge, stop going out when it reaches the highest vacuum.
  #57 (permalink)
Old 06-29-2012, 08:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Put the stock jets, springs and rods back in it as the baseline and adjust/tune from there. Changing the calibrations w/o a baseline to work from is useless and will only serve to confuse you. After baselining it, change things one at a time using the performance and plug color as your guide.
Set the idle mixture screws to give the highest idle speed or highest vacuum reading if you have a vacuum gauge.
Your carb is very close to an Eddy carb. Rods, jets and springs interchange.
Edelbrock Owner’s Manual covering Performer and Thunder series carbs- HERE. With the info from it and from Edelbrock Performer Series Carburetor- Complete Guide to Set-Up, Tuning, and Performance Jetting, and for reference- Detailed Rebuild Instructions, you can go about adjusting it for better performance.
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 04:04 PM
Edelbrock carb. won't fast idle seawolf18 Engine 3 09-09-2011 05:22 PM
Edelbrock Carb Won't Idle Sinister Engine 7 12-21-2009 07:09 AM
center tri carb won't idle... kbyounger Engine 9 05-01-2008 10:08 PM
Truck won't idle...Need Help mudbog42 Engine 14 03-01-2008 04:16 PM
