So I was having major issues with my quadrajet and instead of taking on the daunting task of rebuilding a carb foreign to me in two days I decided to re-jet and rebuild a 650 carter afb I had laying around. So everything went smooth the floats are adjusted properly everything is in right but now the truck wont idle and you have to feather the gas to keep it going. It has no choke as it originally was off a circle track car and it ran fine on my 350 with no choke just a little cold blooded in the morning, but if i stick the choke closed now the engine idles but even if I wait until it hits temp as soon as I open the choke back up it sputters and dies
I'll give that a try, I really dont think cleaning is an issue, this carb ran fine before it was just too big for my 305 so I only got the kit for the gaskets that I knew would get messed up trying to jet it.
Remove your primary boosters, there should be two small brass orifices in each one, clean the hell out of each one, the smaller one if your idle bleed, it needs to be spotless, and has a tendancy to fill with crud. Next follow that orifice through the main body, remove your idle screws and blast the passage ways clean with carb cleaner. When you set your idle feed screw go all the way in and back it out two turns to get a baseline, tune from there with a vacuum gauge. there is most likely crud in your idle bleed and no amount of magic acid pressure wash will take care of it if you don't know what you're doing. The other brass tube is your emulsion circut and should also be spotless for best cruise performance.
No I meant I dipped the entire thing and blew all those out with compressed air, I got the thing to idle but now as soon as i put it in gear it dies. I'm not saying cleaning isn't the problem but the carb was in perfect condition before I tore it down and I spent an entire day cleaning and blowing out every orifice and crevice
It wouldn't idle better w/the choke closed unless it's getting extra air from somewhere other than through the airhorn. So it sounds like there's a major vacuum leak. Check the base gasket, the PCV hose and valve, and all the other vacuum ports and accessories that may be connected to the carb to see if you can isolate where the extra air is getting into the engine from.
Less likely but still a possibility is there's nowhere near enough fuel reaching the engine, so the choke needs to be used to get the air/fuel ratio rich enough to run. That could be from too low floats, sticking needle and seat, wrong or faulty gaskets, wrong jet/rod combination, too large air bleeds, etc.- but most of these things effect the idle a lot less than elsewhere.
What happens when you screw the idle mixture screws out? In? As in, do they change the idle at all, or are they unresponsive?
A vacuum leak could also be the culprit, most of the rest isn't an issue at idle though, you can literally remove the rods and jets and an afb carb will still idle, the circut is completely independant.
Sorry guys been tinkering with it and trying to get to work, it was, according to edlebrock specs, a 600cfm with 398 secondary jets and 395 primary jets the rod size escapes me. I jetted it down to a 500 and (again per edlebrock specs) used 395 jets for the secondaries and 386 jets for the primaries and I believe they are 65x42 rods (not positive) but I used their specs. If I adjust the idle mixture screws idle does adjust accordingly. Right now I have it idling but my mixture screws are out FOUR turns... This is un heard of to me... If I stab the throttle it will die, but if I feather it up then stab it it runs amazingly, picks right up, no dead spots. But if I drop it into gear it sputters and dies. I checked for vacuum leaks, nothing, I sprayed every vacuum hose, cap, and every gasket with ether and no change. I've heard stories of these airtex pumps putting out sub par pressure and I'm starting to wonder if thats my problem. I'll see if I can rig something up to check the fuel pressure as I live in the country and with my truck down have no transport to town lol
I have an edelbrock I run at 2psi... it has larger needles but it doesn't take much pressure. I'm willing to bet one of the idle circuts is now clean and the other is still clogged- if you don't have a vacuum leak. The idle air bleeds on the boosters always gave me problems and id start there. For revving up from idle try moving your accelerator pump rod into the hole closest to the pump, this will supply the most fuel when you hit the throttle.
I tried moving the pump arm, it did make a difference in throttle response but to no avail. I did however notice that when I double checked for leaks some of the carb cleaner (I'm out of ether) pooled around cylinders 2 and 4 and was bubbling... I tried all the others thinking maybe it was just heat from the heads boiling it but none of the others did it... Have I found my deathly leak? I always assumed it would suck not blow if one of my intake runners were leaking :smash:
If your leak is there those plugs should read leaner than the rest, or be wet if its so lean its not even firing at times. If it is a vacuum leak, and you do fix it, return the carb to stock settings and adjust from there.
I'm going to pick up the intake gaskets at work today and swap em tomorrow, I'll post results. I'm not trying to disregard your cleaning idea ap I just have a gut feeling its not in the carb. If this doesnt work then I will take the carb back apart as you suggested thank you for your replies and as always cobalt its been a pleasure lol :thumbup:
I was always taught not to use a sealant on the intake gaskets, the rubber ones yes, but not the ones where it mates to the heads, should I use some there also? And if so what would you recommend?
I just use black rtv, I believe cobalt uses 3m window sealant or something like that. I've never had a problem with a good even smear of black rtv. Be sure both mating surfaces are clean and dry though.
Thanks for the info guys, that goes against everything I've been taught, its like theres a whole new world out there lol. I've always used something called "the right stuff" by permatex, I think I'll give that a try
So it may just be that I'm exhausted but i'd like some input on the situation. So I replaced the manifold gaskets and put a new intake on it, I had an edlebrock air gap laying around, and got everything back together and tight and leak free. I got the engine to run decent and just on the factory settings for the carb, no more four turns out lol. It was running okay but not smooth, I had around 12-14 vacuum at idle and 18 when I hit the throttle, it would even idle In gear just fine. But the thing that bothers me is it wouldn't smooth out, almost like I had a lumpy cam. Now I can't do anymore until tomorrow because as I was putting the air cleaner on for a test drive and it died, then I found out my fuel pump wouldn't even pump fuel up to the carb. So do you think the rough issue was the fuel pump going out or does it sound like I still have a gremlin in there somewhere?
Yes I had to remove the distributor to swap the intakes so I triple checked the firing order before I tried to star it
No it didn't seem have any real rhythm to it it just dropped down when idle dropped
The initial timing no, I still don't have a timing light, I'm so use to doing it by ear but I get paid in the morning and, funds allowing, I'll pick one up
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
