Truck won't idle...Need Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2008, 11:12 PM
Ok well just put my motor back together after replacing an intake gasket and now it won't hold idle , and I am at a loss here is the link to my thread of what's been going on
http://coloradok5.com/forums/showthread.php?t=226748
Old 02-29-2008, 07:18 AM
yep, your distributor sounds like it is in the wrong position.
Pull it out, put the engine on tdc, and put it back in with the rotor pointing to the 1# position on the cap.
Old 02-29-2008, 08:17 AM
T-bucket23's Avatar
Wiki Edits: 26
I read through your other thread, if your heads were shaved on the block side and the intake surfaces were not also machined, this could be your problem. Depending on how much is taken off the engine side of the heads, the intake side will need to be shaved also to compensate. Never shave the manifold, always do the heads, if you machine the intake then it wont fit a standard application if you ever want to re-use it.
I am sure one of the engine builders on here has a good easy trick for checking the mating surfaces. There is probably a way to put some marking compound on the heads and then check the transfer onto the intake.
Old 02-29-2008, 08:27 AM
But if that was the problem why did it go for a year without any problems, and before the edelbrock was put on it still had the stock manifold on there?
Old 02-29-2008, 08:50 AM
T-bucket23's Avatar
Wiki Edits: 26
Have you tried putting the stock manifold back on. Perhaps it was shave to fit the heads. I dont really know if this is even close to your issue, I was just throwing out a suggestion based on your other thread. If the intake keeps leaking antifreeze with several sets of gaskets and being re-installed a few times, there is an issue somewhere. You probably also have a vacuum leak which is causing your no idle condition.
Never assume anything. You never know what someone before you has done, the fact you cant get the mainfold to seal is a good tipoff that something is wrong from an alignment respect. Tey the old manifold and see what happens
Chet
Old 02-29-2008, 08:52 AM
engine won't idle
i just had the same problem, my motor home wouldn't idle but would drive good otherwise.
it had a vacuum leak, seem a squirrel needed rubber and electrical wires fot a diet. i took it my mechanic and he fixed the problem.
try squirting a thin oil, WD40 etc,around the intake where it mates,if you see smoke, it is sucking air.
hope this works,good luck
Old 02-29-2008, 09:41 AM
Chet
I would, but I don't have the stock manifold anymore
The last motor was never touched, it was bone stock and I put the jasper motor in about 3 years ago in 2005 and it was fine, and a year ago, I put the edelbrock manifold on and it was good for a year until now.
Also this time with the edelbrock gaskets it has not leaked thus far
Old 02-29-2008, 12:56 PM
T-bucket23's Avatar
Wiki Edits: 26
Hows the vacuum reading at the slowest you can get it to idle.
Old 02-29-2008, 01:00 PM
life is a temporary assignment
Sound's like you have a vacuum leak some where's.
T-bucket23's Avatar
Wiki Edits: 26
What carb do you have on this setup. And could you elaborate a bit more on exactly what it does. Like does it pop and die or run rough and die, what is the slowest you can get it to stay running. The more info the easier it will be to help you.
Have you double checked the firing order, and what do the plugs look like.
Chet
Old 02-29-2008, 10:08 PM
Ok Ok.....
Don't laugh too much, but for as many times as I have taken a carb on and off, especially on this truck, somehow I managed to put the carb gaskets on backwards, thus creating a very big vacuum leak at the base of the carb.
Found it by spraying carb cleaner around the manifold and carb.
BTW the manifold was sealed all the around, no vacuum leaks on it anywhere....or coolant
So flipped the gaskets around and she runs B-E-A-utiful.
Still can't believe I managed to do this...
Thanks for all the help, I really appreciate it,
Thanks again
Old 02-29-2008, 10:10 PM
Old 03-01-2008, 02:17 PM
T-bucket23's Avatar
Wiki Edits: 26
Thanks again
Join the club, sometimes we just amaze ourselves.
Glad you got it running
Chet
Old 03-01-2008, 02:51 PM
we need a "bloopers forum!"
my favorite for me is I made the slickest ever "custom" radio bezel mount so the aftermarket radio looked totally like it was OEM....
leaned back, admiring how really great it looked.....DUMB SH##...I installed the radio upside down!!!!
(was tempted to leave it that way....just for laughs)
Old 03-01-2008, 03:16 PM
RippinRon's Avatar
Easy fix! Glad you didn't end up having to replace the intake gaskets.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 05:04 PM
replacement pickup truck - your advice please jojo99 Engine 3 04-28-2006 04:48 PM
little eddy-1950 chev truck lowbux Introduce Yourself 5 03-05-2006 11:47 AM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
