Truck won't move til 4000 rpm - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2005, 09:29 PM
406S18's Avatar
434ci S10 Member
It's a 434 small block mated to a TH400 tranny with a 3500 stall converter. Starting in first, I feel like I have to rev it to the moon to actually go somewhere. What's goin on with this?
Old 04-22-2005, 02:22 AM
dawg's Avatar
NAVY VETERAN
did it function ok before?
or did you just put that high stall converter in?
sounds to me like you got a high stall converter and until you reach the flash rpm it isnt going to move.
Old 04-22-2005, 04:35 AM
Last journal entry: Robs34 - Done my dash
Its happened to a lot of us !
Um without wanting to state the obvious, are you sure that the trans is full ? I have had a few hi stalls the last was a 3500 and it allowed me to move before lockup quite easily, if you added a cooler as you should have you will need quite a bit more fluid to compensate. If the trans is full the likely cause is the one way clutch in the convertor or the stator.
Cheers from Oz
Rob
Old 04-22-2005, 10:35 AM
406S18's Avatar
434ci S10 Member
It's all brand new...Just started driving it. The dipstick shows full. I figured it would roll easier. It actually got stuck on a speedbump til I reved it high enough.
Old 04-22-2005, 11:18 AM
Frisco's Avatar
Glad To Be Here
A high stall converter should not need to be revved up high to get the vehicle moving. The high stall does not prevent that.
I also would have suggested that the fluid was low as the other poster replied.
Are you certain that the converter is fully seated to the trans. If not the pump in the trans won't turn and this will burn up the trans quickly.
Old 05-02-2005, 09:04 PM
406S18's Avatar
434ci S10 Member
Alright I took some pics....I removed the converter bolts and tried sliding the converter in further. It went about 3/16" more but now it sits that far away from the flexplate. Could anyone tell me what the deal is?
ID:	4843   Click image for larger version
Old 05-03-2005, 06:21 AM
66Caprice's Avatar
Move It On Over!
Now that's gotta be embarassing!
Before you installed the converter, did you pour about 1 quart of fluid in it?
Old 05-03-2005, 08:42 AM
406S18's Avatar
434ci S10 Member
Yes I did put about a quart of fluid in it before installing it
Old 05-03-2005, 05:52 PM
lluciano77's Avatar
Short changed on common sense
It sounds like you burnt up the tranny.
Did you hook up the modulator?
Did you try to shift while it was low on fluid?
Did you have the shifter adjusted wrong? A friend of mine had a TH350 that was adjusted wrong. The shifter shifted half way between first and second. Bye Bye tranny.
Old 05-03-2005, 06:03 PM
poncho62's Avatar
Wiki Edits: 5
Either a faulty converter.........or the tranny is fried in my upinion.....................
Ontario Rodders
Old 05-04-2005, 12:42 PM
406S18's Avatar
434ci S10 Member
So why does the converter sit 3/16" away from the flexplate right now? And with the modulator....I have a piece of rubber hose coming off it about 3 inches..Does this need to be hooked up to a vacuum source?
Old 05-04-2005, 03:12 PM
poncho62's Avatar
Wiki Edits: 5
Yes, the modulator valve needs to be hooked up to manifold vacuum.
Ontario Rodders
Old 05-04-2005, 07:16 PM
406S18's Avatar
434ci S10 Member
So I know there's only one way to find out but..could this be my problem?
Old 05-04-2005, 09:47 PM
Crosley's Avatar
Wiki Edits: 1659
if the modulator and the valve it works against inside the tranny is installed... it nothing to do with the vehicle hardly moving.
Vacuum hose or no hose, if the tranny was built correctly it will move the vehicle.
there are many different items that would cause no or little movement from low fluid to sealing rings left off the pump during the install.
You will have to diagnose this problem by checking 1 item at a time...... fluid level, pressure in various shifter positions. Pull the pan to see things are correctly installed.
Then the tranny may need to come out.
Old 05-05-2005, 06:31 AM
Ghetto Jet's Avatar
pic of my Cobra should be here
Last journal entry: Lets Get Started With the Improvements
you need to put washers in there. I had to do the same thing with my 200R4.
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
Ebay Truck Headache CrashFarmer2 Hotrodders' Lounge 8 09-06-2003 07:30 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
