Truck won't start unless I play with shifter- neutral relay switch bad? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2004, 06:32 PM
BobbyG-39's Avatar
Designer, Artist, HotRodder
Sometimes, ( more often than not ), my 39 Ford Panel will not start unless I either wiggle or hold the gearshift to the right in Park when I turn the key.
I have been told this is a neutral relay switch, apparently, to prevent the car from being started in gear.
Anyone ever have to replace one of these things? I assume not many, since I couldn't find squat in the search or Knowledge Base.
Old 08-10-2004, 06:43 PM
poncho62's Avatar
Wiki Edits: 5
Depends on where the switch is..............some are on the column, some are right on the tranny, or even the shifter. If you have a GM column in it, its probably on the column.
You have to find it 1st.
Old 08-10-2004, 06:47 PM
BobbyG-39's Avatar
what exactly am I looking for?
I know what its called, I just don't know what it looks like....
Old 08-10-2004, 07:05 PM
poncho62's Avatar
Wiki Edits: 5
Obviouslly, you don't have a stock steering column in it. You will have to find that out before we can help.
If it's a GM column, its a curved switch on the column under the dash. Has wires going to it.
Old 08-10-2004, 07:59 PM
docvette's Avatar
Wiki Edits: 12
Neutral Safety Switch.
[color=yellow]Doc Here
If It's General Mystery(GM), and on the Column....
It Should look like this:
Doc
[/color]
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-11-2004, 06:02 PM
BobbyG-39's Avatar
Thanks- I'll check it out.
Not sure what kind of steering column it has. Was built in several shops around SoCal by previous owner.
