Truck won't turn off.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2011, 08:19 PM
dum dum hooked battery up wrong
84 c-10 hooked battery up wrong now my truck will start but will not turn off what do i need to do????
Old 01-01-2012, 07:45 AM
Greg T's Avatar
www.krusinklassics.net
Probably smoked the diode tro and rectifier in the alternator. If I remember correctly this will cause a bleed-thru and keep the ignition energized. Have you checked the charging sysem?
Old 01-01-2012, 10:11 AM
LATECH's Avatar
Last journal entry: New Gas Tank
X 2 what Greg said. I think he nailed it.
The easy thing to do to check this , is to completely disconnect the alternator then start the car, then shut it off, if it works fine , then replace the alternator.
Old 01-01-2012, 11:18 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X3
Cole
Old 01-03-2012, 04:53 PM
Look I hooked up my battery wrong and arked out what I thought was my dido so I spent $100 bucks on a new alt.My truck will start but will not turn off unless I unhook the alt & batt.What switch do i need to replace?????or what do i need to look for,HELP........I'm sol right now.
Old 01-03-2012, 05:46 PM
DoubleVision's Avatar
The problem sounds like simply its not killing the power to the distributor when you shut the key off. Your gonna have to run some tests to find out why its not killing the power.
Old 01-03-2012, 05:49 PM
topwrench's Avatar
Last journal entry: fish carb
what make, what year,what engine?
What is a dido?
Do you mean the diodes inside the alt?
Old 01-03-2012, 06:19 PM
68NovaSS's Avatar
Wiki Edits: 9
You have two threads with the exact same issue, I have merged them here. Please to not double post, there were responses being made to the first thread.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 01-03-2012, 06:36 PM
LATECH's Avatar
Could be backfeeding through the radio memory/power circuitry from a bad diode there. Did you even try unhooking the alternator and doing the test that was suggested before buying an alternator? It would have saved you 100 bucks.
Now that your wallet is lighter, maybe try unhooking the radio and trying it again.
need wiring diagram for brake lights turn signals on 77 Chevy C30 truck mike 96 ws6 Electrical 5 09-04-2011 04:30 PM
LMC truck, great turn signals-lost diagram Footstomper Electrical 1 01-29-2011 11:10 AM
62 chevy truck turn signal truck man Electrical 6 10-11-2006 05:04 AM
59 Chevy Truck Turn Signal Assembly garretthes Electrical 1 12-05-2004 11:56 AM
turn signal wiring for '82 Chevy truck jimfulco Electrical 2 10-16-2004 10:09 PM
