A "TRUE"305 - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-19-2011, 03:26 PM
V8 super beetle, belive me this is no disrespect,im just learning all this,but on that 305 build they use a set of slightly under fed 350 heads. So why not just use 350 heads to start with or port & polish the 305s? Why is the 305chevy such a dead dog compaired to the 302ford? Both 5.0s kinda. My class mate did a"bolt on build" to his 85gt.foxbody & he eats SBCs all day!,why the big diff?
  #32 (permalink)
Old 04-19-2011, 03:47 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Those are "350" heads they used, well, they're best suited for a 350 anyway. Can be used on a 305 or 400. Depends on what you're after. The intake runner size (180 cc) and chamber cc (64 cc) are a little large for a 305. A 305 with these heads would be soggy down low and you'd have to wind it up to produce power, which is the case in the article.
If you read the article, you'll see they machined the heads by .040 to arrive at a 58 cc chamber vs. the 64 cc size, which was necessary to bring the compression ratio up to around 9.5:1 with the dish pistons.
A 305 can be built to perform, as you see in the article, but the same parts on a 350 would produce about 15% more power and torque due to the larger displacement of the engine. Engines are just air pumps. The more air you can pump in the more power you will get in return.
If you go to the drag strip, you'll notice most of the cars are chevy's or they're running chevy motors. That's cause you get the most power for your buck due to the popularity of chevy's.
Fox body mustangs are light and it's easy to get some decent power out of a 302 for cheap. Again supply and demand. It's all about power to weight ratio. I would be glad to run him in my bug with my 383 SBC. It'll be a tough one for him to swallow.
Gearing and converter size make a big difference too.
305's were really never meant to be a race motor. It was built for torque and fuel economy, well, that's my understanding anyways. They tend to run out of power after about 4500 rpm due to their heads.
  #33 (permalink)
Old 04-19-2011, 04:23 PM
Super beetle,thanks for the follow up info,every bit helps! Ya,im sure you could beat his foxbody he only has $3200 in the whole car & is only running high 12s. Your bug should be down in the high 9s/10s? My tech shop teacher would take that offer with his low 8s 501 Arrow!That's with a throttle stop & delay box for his class. There is a huge pic.of him racing in Denver Col. 07.in the super pro class non-restricted event. He was turning out 7.56s @ 184.23mph.
  #34 (permalink)
Old 04-21-2011, 08:40 AM
My friend was wanting to know if anybody knows of fourms for trucks built for drag racing? He is the one i spoke of with the 3/4ton chevy he toys with. Any help would be great.
Thanks!
"THAT'S TRUE" OR "YOU'RE LYING" OLNOLAN Hotrodders' Lounge 30 09-20-2009 08:36 PM
Is my Monte Carlo SS a "True" SS Lance1 Hotrodding Basics 3 02-15-2009 06:54 AM
preplanning a "true" rat rod Shoez Hotrodding Basics 17 12-20-2008 05:15 PM
Some "Guy" humor, how true it is Jmark Off-Topic 3 12-25-2007 07:40 PM
"Wrecks to riches" GTO "True Blue" Blackdog Body - Exterior 14 04-23-2006 03:25 PM
