IS THIS TRUE >> ? ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2006, 06:14 PM
MINING CAMP's Avatar
Hello,
I ran accross some info that I wondered if it was true. I found an old sign on auction that stated that in the 1940's people use to use VIX Vapor to try to improve gas and oil consumption.
you know the same stuff you use for a cold!! Mayby I am wrong but let me know if anyone else has herd of this.
Check out the auction for this sign at 7229988211
Old 04-01-2006, 08:39 AM
willys36@aol.com's Avatar
Wiki Edits: 21
That's an ebaY auction incidentally. Can't argue with the sign- someone must have bought the line back then but I doubt a whiff of eucalyptus oil vapor will turn your car into a Toyota Prius overnight! Screams of Urban Legend.
Old 04-01-2006, 09:32 AM
powerrodsmike's Avatar
Wiki Edits: 161
I don't know about making the car run better or save gas, It would make it smell better though
BE different....ACT normal.
Old 04-01-2006, 03:40 PM
cboy's Avatar
Last journal entry: Finished
I've also read on the internet that Vicks is good for eliminating toe nail fungus. My guess is somebody, somewhere, has tried it for just about everything.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 04-01-2006, 04:35 PM
Funny
Thanks is funny Vicks use to be the Mechanics windex. (I.E. Greek weddingthe father using windex to fix and heal anything.)
Old 04-01-2006, 11:07 PM
Wiki Edits: 21
Technology on parade - now instead of Vicks it is WD40 that does all that stuff.
Squeeling Fan Belt - Out of true Pulley Billy Boy Engine 3 02-15-2005 06:51 PM
A true Hot Rod Nightfire Hotrodders' Lounge 10 10-18-2004 04:40 PM
True Duals dannimo Engine 4 01-26-2004 04:03 AM
True Duels vs Duels with H-Pipe dannimo Engine 2 01-08-2004 05:27 PM
true Track posi streetk14 Transmission - Rearend 3 01-07-2004 12:11 AM
