Trunck Lid Not staying up - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2012, 08:23 PM
I am trying to help a friend out on his 1985 Monte. Here is my question: On the passenger side in the truck is the tension bars under the back deck. The arm that holds the truck lid up and open is off. The piece I am referring to is the double u shaped arm that attaches to the single u shaped rear tension rod.
How in the hell do I get that piece pulled down enough to get the truck lid arm back on there so the lid stays up?
I had crow bars up in here, wedges and sorts trying to pry that thing down enough to slide the hinge arm back in, wow is that thing tough.
I was just thinking and thought maybe a ratchet strap hooked up in there on the u shaped rod and one through the back seat onto something?
Thank you,
Old 06-04-2012, 09:28 PM
This method works perfect on those trunk hinges as well. "Basics of Basics" hood hinge spring installation.
Carburetor: Carter AFB staying open after WOT Alimony Bob Engine 5 11-27-2010 04:10 PM
Reverse Lights Staying On While I Am In Gear 350chevypower Electrical 12 05-20-2009 01:11 AM
what lid would be better ? spinn Engine 3 04-17-2007 11:24 AM
Seam sealer staying tacky :( Ripped Body - Exterior 4 10-16-2005 12:36 AM
Have problems get on and staying on hodrodders.com 406chevelle Hotrodders Site Suggestions and Help 11 12-10-2004 07:30 PM
