Trunk Handle Lock Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2007, 07:33 PM
Thirty Seven Ply's Avatar
Hi,
I found a trunk handle for a 1937 Plymouth at a swap meet.
It needs to be rechromed so I want to take it apart. I removed the C clip and took off the mounting plate and spring. Does anyone know how to remove the lock cylinder?
TIA Barry Schell
Old 03-02-2007, 09:12 PM
awert's Avatar
58/58
I have done it
I'm a newbe here and NO expert, but i have done that on my 47 Ply. It was many years ago but if i remember right you need the key, turn the key in the lock cly. then you have to push the pin down, and pull the cyl. out. sounds ezy but the things can get rusted in there real bad. But in short that small pin has to be pushed down so can can pull it out.......
Old 01-22-2011, 03:28 PM
trunk lock removal
I have a 49 DeSoto and your comment worked! Insert the key, turn it until the pin can push down and then it pops right out.
thanks!
Old 01-22-2011, 06:46 PM
awert's Avatar
58/58
The 49 De soto what a nice car, i was hoping to find one when i sell my 58 Ford.
Almost finished fitting / shaping f/g trunk, starting the hood Ripped Body - Exterior 3 05-05-2006 06:50 AM
How to fix trunk lock hole? MM in NM Body - Exterior 3 03-06-2006 09:17 AM
1964 ford galaxie door handle removal raymrajak Interior 8 10-09-2005 10:51 PM
suicide trunk sirsleepy Body - Exterior 14 09-13-2003 01:46 AM
Trunk idea Wmarden Interior 13 11-07-2002 12:11 PM
