Trunk Latch - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2013, 10:48 PM
Trunk Latch
I have a '40 chev coupe that has power lifts which is operated electrically by the battery (when it's not gone dead and it's in the trunk). I've had too many times where the battery has gone dead or the lifts are very slow. Has anyone seen or replaced their trunk/handle latch with just an outside-key-sort of latch? My friend has one on his '48 Merc. coupe which is slick, but he has no idea where it came from. All he does is insert the key, turn it and the trunk unlocks....no power. Looks like a passenger door key latch of some sort (small disc shape). Would appreciate any info. on something like that.
Old 05-01-2013, 03:58 AM
Trunk latch
If you're looking for a REAL small key type of latch, check out the trunk latch on the 94-? Chrysler LHS/300's. The keyhole is no bigger than the main shaft of the key ( about 1/2 inch or slightly less if I remember right )But you could maybe make or adapt something like that. Maybe even fab up a small "holster"on the inside of the lid so that you could slide a regular GM trunk key cylinder asm. real tight against the inside of the lid . Then have a small hole in the decklid that the key would go through.That way all you would see would be the center of the key cylinder. Of course it would need to be sealed to the lid. Sorry if I didn't express myself clearer. Maybe one of you other guys understand better, and can provide a drawing?
The Following User Says Thank You to F1 Owner For This Useful Post:
27Tall T (05-01-2013)
Old 05-02-2013, 09:04 AM
ogre's Avatar
the 'Duracell Project'
i use an 00 mustang trunk latch on my truck
it has 3 means of unlatching itself; key on cable, hoffa release and electric release
i removed the key function and used bicycle brake cable and hardware to run the unlatch cable inside.
normal use is electric release w/ cable back up
though you could do the same thing with a small bearclaw and use bicycle cable to open it
The Following User Says Thank You to ogre For This Useful Post:
27Tall T (05-02-2013)
wiring help Pull Down Trunk Latch from a cadillac sickolds Electrical 0 12-26-2010 03:07 PM
Pull down trunk latch freedom53 Electrical 7 01-16-2008 04:29 PM
Pull Down Trunk Latch gow589 Electrical 7 08-30-2006 11:10 AM
trunk lid latch markl Body - Exterior 1 11-10-2005 04:15 PM
Trunk Lid Latch/Lock for 28 Ford Doc68 Body - Exterior 2 11-10-2003 09:33 AM
