trunk lid - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-30-2010, 06:03 AM
HaydenP's Avatar
Trying to attach pictures, lets see if this works.
Name:	Copy of IMG00001-20091105-1301.jpg
ID:	45460   Click image for larger version
ID:	45461   Click image for larger version
  #17 (permalink)
Old 04-30-2010, 06:08 AM
HaydenP's Avatar
Okay, that worked. The first pic is basically just the back of the car - shows no top damage, hasn't been wrecked or beat. In the next pic, the car has been primered so the grey portion is the part under the window the black is the trunk lid showing it is raised in the middle of the top straight edge. The last pic is another view to hopefully shed a little more.
  #18 (permalink)
Old 04-30-2010, 07:16 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I purchased a Trunk Lid from Wescott's for my '35, and it did not fit. I used original Trunk Hinges, and it fit good at the front, however the rear corners would not fit-it was either high in the middle, or it was low in the corners, no matter what I did to adjust, tweek or shim. The workmanship of the part is very good, but I had to do some MAJOR slicing and dicing along with Fiberglass work to get it right.
I attributed it to poor quality control at Ford-
  #19 (permalink)
Old 04-30-2010, 07:25 AM
You need to reduce your picture size. Go to the menu on your camera and change it. You will also get a LOT more photos on your chip if you do this. As you have it, ONE of your photos is taking the room of 20. I am surprised you were even able to load it here.
Get this down and you will be a lot better off. Photos and the internet go together, when I think of how much faster I could have learned things 30 years ago if I had what we have here.....
  #20 (permalink)
Old 04-30-2010, 08:15 AM
Irelands child's Avatar
Wescott's is the best of a lot of 'glass after market car part suppliers most are ho hum. I have their fenders on my AVATAR car and I can assure you that there was much work to do on them to make them fit right. First of all, they were warped from continued curing after the were removed from the mold. I bolted them on anyhow as best possible, used a bunch of weight, bungee cords, rope and clamps then turned on some heat lamps under a tarp. They came close after about a week of "playing" with them. Next, the fit at the running boards was just plain bad. These had to be glassed, steel reinforcing added then ground to fit. I had looked at repro steel front fenders - and they were even worse.
DURING FITTING
ABOUT DONE
But with that said, I would pursue an OEM trunk lid. This vintage car ('35-'40 is my time line) was/is a major PITA to fit body parts even using Henry's original pieces
Dave W
Irelands child
  #21 (permalink)
Old 04-30-2010, 08:30 AM
302 Z28's Avatar
Dave W
You said a mouthful Dave.
Vince
  #22 (permalink)
Old 04-30-2010, 08:44 AM
35WINDOW's Avatar
Wow Dave,
I had no idea that you had so much trouble-gee, I have a lot to look forward to! I know a lot has been discussed regarding the curing of Fiberglass parts and how the vendors make/cure them. I had considered using JB Donaldson Fenders on my car due to how they cure them, however I still beleive Wescott's to be the best-I'm concerned now-
  #23 (permalink)
Old 04-30-2010, 08:50 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
i've dealt with glass cars for years. they are a pia but all are. a glass fender is not going to lay in the floor and keep it's shape. period . even building with all steel is a pia . these cars were pos's when new. the number one tool on the assembly line was a 2x4 . jb uses tooling gel for his cars ( vinyl ester ) and makes on hell of a fine car .
  #24 (permalink)
Old 04-30-2010, 08:58 AM
35WINDOW's Avatar
Thanks for the insight Shine-do you know what type of Resin Wescott's uses, or any insight into who makes a better part (Wescott's or Donaldson?)?
  #25 (permalink)
Old 04-30-2010, 09:08 AM
shine's Avatar
SPI Thug
vinylester is the holy grail of resin. i have never seen it but have heard jb has a body setting out back in the sun thats been there for years. don (da34guy) has most likely been by there. wescott builds a nice car as does jb . be a tuff call between them. but as with every business people get older and sell out or turn over to the kids. we all know what happens then.
  #26 (permalink)
Old 04-30-2010, 09:21 AM
302 Z28's Avatar
Case in point...Gibbon Fiberglass
Vince
  #27 (permalink)
Old 04-30-2010, 09:35 AM
....and since Dee Wescott went to the big 'glass shop in the skies last year, makes me wonder what will happen there.
Unfortunately, for my car - JB Donaldson doesn't make a single part so had to use the best available. Their web site - crappy
Dave W
Irelands child
  #28 (permalink)
Old 05-01-2010, 05:03 AM
deadbodyman's Avatar
Wiki Edits: 11
www.bobdrake.com
have some respect for the car...
  #29 (permalink)
Old 05-01-2010, 10:25 AM
Originally Posted by deadbodyman
www.bobdrake.com
You're a rebel aren't you! I agree, but I would keep looking for a nice (or not so nice) original. I would rather have an original panel ran over by a truck that I have to fix than run a repro anything, glass, steel, I don't care, I want ORIGINAL parts. But that is just me, just my personal opinion.
Not only do you have some Chinese crap or a piece of a hot tub on your car it often needs as much work as a screwed up original anyway!
Hayden, you checked Craigs list and ebay, how long did you look? Do you have tickets to the theater next week and need a lid to take your honey in the 40?
I have been looking for parts for my 1948 Chevy pickup, it is AMAZING what pops up when you least expect it. How about NOS fenders, see them all the time, how about an NOS 53 Corvette intake for the motor, I bought it. NOS distributor for the 1955 235 in it, bought i on ebay. NOS gas pedal, bought it on eBay. The stuff is out there, don't be in a hurry.
I have a 59 Rambler, I have bought all the brake parts for it off ebay one piece at a time over a few months. All BRAND NEW OLD STOCK, for pennies of what I would have paid at one of the AMC Rambler supply places around the country. Paid $14 for an NORS (New Old Replacement Stock) water pump where they are $65 for a rebuilt. Front wheel cyl are about $45 each, got a pair on eBay (NOS) for $30.
When I first went looking I found nothing, then I started finding the AMC specialty stores, awesome, at least I know where to get them, but damn they were expensive. I kept looking, and they started turning up every week or so I got another part. That is why they call it a search, because it takes a while.
Come on now, there are zillions of those lids out there. But you won't find it in an afternoon on the net or with a few phone calls. It isn't like looking for a pair of small block Chevy headers, you won't find it at the corner store. Just multi task dude, work on another part of the car WHILE you are searching for another lid.
One will turn up when you least expect it, relax, the search is one of the funnest parts of building an old car.
  #30 (permalink)
Old 05-01-2010, 10:35 AM
By the way DBM, this pedal at the link you posted is DAMN interesting!
http://store.bobdrake.com/b-2454-a.html
Gas Struts for Trunk Lid ogre Body - Exterior 25 05-16-2010 11:41 AM
Fat Fender Trunk Lid Lift Help redsdad Body - Exterior 4 11-23-2009 08:32 AM
trunk lid seal jovilinc General Rodding Tech 1 10-15-2009 07:45 AM
86 Camaro Trunk Lid Motor Stuck! BuickGuy Interior 3 04-21-2006 05:30 PM
Trunk Lid Latch/Lock for 28 Ford Doc68 Body - Exterior 2 11-10-2003 09:33 AM
