Trunk Lid - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2011, 02:47 PM
Trunk Lid
Does anyone know if a 64, 65 tempest GTO has the same trunk lid or is there
a style change. I purchased a 1964 GTO car is very good except i am thinking the trunk lid is an after market find does not want to close quite right
Old 03-07-2011, 03:06 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Don't hold me to it but i'm pretty sure they were somewhat different. At the back where it drops down to meet the rear. JMO
Cole
Old 03-07-2011, 03:19 PM
LATECH's Avatar
Last journal entry: New Gas Tank
I havent seen the difference but what cole said is correct. I have a diehard pontiac guy in wrightsville ,pa who I bought a ton of parts from and he said the trunk lid was different . He said the slope is different as cole said.The 65 is a little taller IIRC.
The crease in the upright is different also.(body line )
I remember because I was asking about the lockcylinder that was missing in mine.
Lots of stuff is 64 only. Makes it a little tougher . The 64 was my favorite years for lots of cars.
The lock cylinder is the same but the lock retainer is different.
Plus there were 2 different styles of lock retainers for the 64
Old 03-07-2011, 03:27 PM
LATECH's Avatar
Hey Fathertime. Check out this place.
http://www.ultimategto.com
You will like it.
Old 03-07-2011, 03:38 PM
LATECH's Avatar
Also you might want to go to ames performance
They have a Pdf. catalog that is great, even if only just for parts reference.
http://www.amesperformance.com
on the left of the page is " download " click on it and choose your catalog to download.
Old 03-08-2011, 04:48 AM
Thanks guys have had a devil of time getting lock to hit strike without a lot of modification. So took trunk off hinges and laid it on body and it looks like it's different across the back. As hard as these are to find guess we will do a little modification. I have purchased a lot of parts from Ames Perf
Old 03-08-2011, 07:09 AM
eloc431962's Avatar
Wiki Edits: 37
That's the area glad you are getting it going now glad to be of some help.
Cole
Old 03-08-2011, 07:17 AM
Thanks Cole
After laying in trunk could see problem area. I know where theres a 64 in my area going to see if i can take a look at his trunk.
Once again thanks.
Bruce
Old 03-08-2011, 08:12 AM
Post some photos. I have owned quite a few of these 64-65 A bodies (Buick Skylarks) and still have one in my garage. The trunk lids fit very poorly from the factory, these are not 2010 cars where fit and finish is so good. They often fit REALLY bad.
If your car has had a new repro rubber seal added the trunk lid WILL NOT FIT. I don't mean "could be the trouble" or "maybe the repro rubber is the problem" I mean if it has new rubber that IS one of the problems, PERIOD, END OF STORY.
Fitting one of these lids under the best of circumstances is taxing and even the best bodyman is going to have a lot of work ahead of him.
So before you jump to conclusions about this lid being repro or what ever you are thinking, POST SOME PHOTOS.
Did you know that the factory lid most always is low in the center across the leading edge of the trunk lid? Yep, but by the rear window they are usually low there, sometimes WAY low. Did you know that the factory used a large hammer to hit up on the inner structure of those lids putting big dents in the inner structure to make them fit on the outside as "good" as they did?
Yep, after restoring a few Skylarks and fixing dents in the inside of the trunk lid inner structure it dawned on me that EVERYONE of them had these dents!
POST SOME PHOTOS!
Old 03-08-2011, 09:01 AM
Thanks Brian
I was going thru pictures of 64's and none that i noticed had holes across the back for a trim piece also. The lid hits on the back corners will post pictures as soon as i go get new sd card for camera.
When i bought this car this is what was on it plus it has a glass hood which i can live with for now as i just would like to fix for crusin. Have all new interior
working on outside.
Thanks again
Bruce
Old 03-12-2011, 09:41 AM
pictures of trunk
Here are the pictures of the trunk and how it sets on the body. Haven't had a chance yet to get over and see a 64 trunk but it looks different from other photos
ID:	53483   Click image for larger version
ID:	53484   Click image for larger version
ID:	53485   Click image for larger version
ID:	53486   Click image for larger version
Old 03-12-2011, 09:46 AM
LATECH's Avatar
Dont go anywhere. Here is a pic of a 65. it wiggs where yours waggs.
The one you have is a POS repop
Old 03-12-2011, 09:48 AM
LATECH's Avatar
That pic cme from the ultimate gto site. You should go.
Old 03-12-2011, 09:51 AM
I have to tell you LaTech someone spent a LOT of time making that lid fit on that Goat, they did NOT fit that well from the factory! I have done a number of these A bodies and owned some super original cars, they didn't fit that good, you can bet your life they weren't even close!
Old 03-12-2011, 09:54 AM
Your pictures are so small they are pretty useless as far as seeing anything of detail. A stone stock original lid with new repro rubber will fit that bad, no joke. Before you throw the baby out with the bath water post some more photos that are a little bigger. I could swipe these and enlarge them I guess and I will do that later but right now I am running out of the house.
trunk lid HaydenP Body - Exterior 33 05-02-2010 07:20 AM
Don't like my trunk, so I need help bonuts Interior 10 03-14-2010 07:33 AM
Trunk Lid renegarceau Body - Exterior 3 12-22-2005 03:32 PM
Trunk Caprice Body - Exterior 2 02-15-2005 06:54 PM
trunk sway Body - Exterior 2 06-30-2004 01:35 PM
