Trunk lid carpet 30 Ford roadster - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2013, 09:47 AM
Hi all I getting my 30 Ford roadster ready for the LH. 2013 Tour. Cleaning up the interior , I`m now at the trunk lid , where I`d like to add some carpet . I`m having trouble getting thin plywood to fit the curve, where I would attach the carpet . Should I just forget about this and just attach the carpet with either glue or velcro tape. Any suggestions.Thanks
Old 04-27-2013, 12:40 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Not unless the hood is perfectly smooth, and you'd need industrial Velcro or it would peel right off as soon as the trunk got warm. If you glued it on, how would you get it off if you needed to? Use 3MM (just under1/8" thick) PVC foamboard, brand names Komatex, CelTec, Sintra, and Palight, which is available at sign shops and sheet plastic suppliers. It will easily curve to fit the trunk deck, and heating it with an industrial heat gun will make it hold that shape. Attach it with door panel clips, and make sure you put a couple clips right at the main curve line. Use the most lightweight carpet you can find.
Old 04-27-2013, 03:00 PM
Irelands child's Avatar
My '31 was done with .062 ABS panel board, padded, upholstered with a soft marine vinyl then attached to the lid using those @#$%%^ spring clips. The wrinkle seen has been taken out as the photo was taken in progress:
Irelands child
Old 04-27-2013, 04:15 PM
Wiki Edits: 22
If you don't like the 10780 spring type clips, use the 12134 clips. They are both offset the same, so they should be interchangeable.
The Following 2 Users Say Thank You to DanTwoLakes For This Useful Post:
Irelands child (04-27-2013), timothale (04-28-2013)
Old 04-27-2013, 07:16 PM
I'll have to give them a try - the others = phew (plus a paint scratcher if not careful)
Irelands child
Old 04-28-2013, 05:15 AM
Wiki Edits: 22
Either one of those two clips can make you crazy sometimes. Just be patient and make sure the point of the clip is centered on each hole before you drive them in.
Old 04-28-2013, 06:13 AM
For sure - but there is always that one that fit 30 seconds ago and 'moved' while you were snapping the next one on the panel in place and why I have a bunch of spares
Irelands child
Trunk Lid Fathertime35 Hotrodding Basics 34 03-12-2011 02:18 PM
How to carpet my trunk lid/deck Longboard Interior 2 10-10-2010 08:32 AM
trunk lid HaydenP Body - Exterior 33 05-02-2010 07:20 AM
Trunk Lid renegarceau Body - Exterior 3 12-22-2005 03:32 PM
Trunk Lid Latch/Lock for 28 Ford Doc68 Body - Exterior 2 11-10-2003 09:33 AM
