Trunk Lid Latch/Lock for 28 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2003, 02:11 PM
I have a fiberglass lid on a 28 ford rod. It is a standard trunk lid, not the rumble seat.
I am having a difficult time finding a locking latch for the lid. Currently I lift the lid using a nylon strap. The Model A latches may work, but I don't like the large handle that come with the latch/lock.
I'm looking for something smoother, less obtrusive, that I can use to lift the lid and lock it. Suggestions?
Old 11-07-2003, 10:39 PM
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
This may work...
Go to the boneyard and pull the hatchback latch assembly from a VW Rabbit.
While you are there, also get the hood latch assembly, complete with inside cable release if it has one.
Either assembly is common and cheap, matter of fact the rod suppliers usually have the Rabbit hood latch available for both hood and trunk use. It consists of a single spring-loaded pin and a simple latch mechanism that the pin indexes into.
If you go with the trunk latch assembly, you can raise the lid a bit after popping the latch with a couple common door poppers, they are just a spring-loaded pin assembly, and lift the lid about an inch or so. Alternately you could get a spring from a hardware store that has one end wound tighter, and use a bolt/washer to retain it to the lid or the trunk lip. The free end of the spring can just butt against the panel, or you can make a simple wear plate from a scrap of stainless sheet.
Doc
Old 11-10-2003, 10:33 AM
Thanks, Doc, for the suggestions. You have given me some good ideas on how to proceed!!!
