I believe the problem is the skin and the inner structure are vibrating together and it is damn hard to get in there to do anything. Just about anything that will take care of it will open up a door for damaging the skin so you see "warpage" on the skin, I know you don't want that!
I also say, turn the bass down. Not a smart ars answer, honestly, you have a choice, screw up the deck lid, or turn the bass down. Make up your mind what you want and choose one. If you choose you want to keep the base, simply put some expandable foam between the two and try to give it a LOT of room to escape so it doesn't split the two in half (it has the power to do so) and get it over with. If the skin has some warps or high spots, so what, you solved your problem.
I personally would leave the bass down, or get a smaller sub woofer or what ever you call it. I mean, that "style" is dead and gone isn't it? I quality sound system that REPRODUCES music is the best way to go and won't have that boom boom being that isn't a part of the music but created to wow your friends. Leave a quality sound system so you can enjoy your music and remove the bass so you don't have to screw up your classic car.
Seems pretty simple to me, but like I said, make your choice and go with it.
