Trunk mounted battery - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2003, 05:01 PM
I am installing a trunk mounted battery. How do I go about attaching the ends that go to the starter and the negative to the frame? Will soldering them work OK?
Thanks
Old 07-26-2003, 06:36 PM
BOBCRMAN@aol.com's Avatar
depends on the type of ends you are using, there are some that do a good job as crimped, some use a compression type fitting, some can be soldered. I've used all three types successfully.
Old 07-26-2003, 08:05 PM
Thanks for the info - every little bit helps.
Old 07-27-2003, 02:23 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
from a safety standpoint make sure you mount your battery in a battery box. battery vapors are highly corrosive along with being highly explosive.
kevin
Old 07-28-2003, 05:06 AM
302 Z28's Avatar
kevin
Good point Kevin, and also make sure you vent that battery box to the outside.
Vince
Old 07-29-2003, 08:12 AM
dollybud's Avatar
Post
Fred56, a few tips to save you headaches in the long run:
1- use 1.0 cable, 2.0 minimum 2- run the ground cable to the engine block, DON'T ground to frame in trunk
3- use copper ends, heat with propane torch, stick in stripped cabe end and fill with solder.
Tom
