Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trunk pan replacement
Old 03-21-2013, 12:42 PM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
I replaced the trunk pan today in a 62 chev. Frist cut out the old pan then ground lip and primed. Set in the new pan after drilling holes for plug welds. Welded and ground plug welds and reprimed new lip on new pan. Seam sealed around the new pan now all thats left is to prime sealer when dry and either bed liner trunk or splater finish. Need to check with owner to see which way to go. 6 hrs start to finish. Not as fast as I was when younger could of had this done in about 4 a few years ago.
Name:	2002-09-13 00.31.28.jpg
ID:	72455   Click image for larger version
Name:	2002-09-13 00.31.33.jpg
ID:	72456   Click image for larger version
Name:	2002-09-13 00.31.40.jpg
ID:	72457   Click image for larger version
Name:	2002-09-13 00.35.51.jpg
ID:	72458   Click image for larger version
Name:	2002-09-13 00.58.29.jpg
