trunk rubber seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2006, 01:33 AM
trunk rubber seal
Im putting a new seal in trunk having a hard time removing old rubber someone used a black gasket glue to put it down its comming out in pieces,is there a solvent or anything i can use to dissolve and lift the old rubber.Anyone with advise would be greatly appreciated thanks
Old 06-26-2006, 05:48 AM
302 Z28's Avatar
3M makes an excellent weatherstrip adhesive remover, it is availiable at better auto parts and paint supply stores. Do not be tempted to use lacquer thinner, it could damage your paint.
Vince
Zoop Seal coating for polished aluminum, RESULTS!!!!!!! fordSR Engine 15 02-05-2010 12:04 PM
49 Chevy..Rubber Trunk Mat eddiebmartinez Interior 5 09-21-2005 11:58 AM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
Rear Main Seal 1985fiero Engine 1 04-27-2004 09:31 PM
Trunk idea Wmarden Interior 13 11-07-2002 11:11 AM
