-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Trunk Upholstery (http://www.hotrodders.com/forum/trunk-upholstery-203599.html)
menace 65 08-12-2011 02:00 PM
Trunk Upholstery
I was wondering when setting up a trunk for upholstery if that PCV FOAMBOARD would work the best,what thickness would be best to use? What glue would be the best if you have to glue a couple of panels together? How do you cut it?
DanTwoLakes 08-13-2011 08:34 AM
PVC foamboard will work fine. I use 3MM thickness, which is about 1/8". You will need a framework of some kind to support it.
You cut it with regular woodworking tools or with a utility knife.
It comes in 4' by 8' sheets, so you probably won't need to glue it, but if you do, crazy glue works well. I have also had good luck gluing it together with foam to foam contact adhesive like K-Grip or K-Spray.
menace 65 08-13-2011 09:41 AM
Trunk Upholstery
What do you generally use to make up the framework in the trunk?
DanTwoLakes 08-15-2011 12:07 PM
You can use plywood, metal, regular wood. Anything to hold the panels in the place you want them.
