Trunk Upholstery - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2011, 01:00 PM
Trunk Upholstery
I was wondering when setting up a trunk for upholstery if that PCV FOAMBOARD would work the best,what thickness would be best to use? What glue would be the best if you have to glue a couple of panels together? How do you cut it?
Old 08-13-2011, 07:34 AM
DanTwoLakes's Avatar
Wiki Edits: 22
PVC foamboard will work fine. I use 3MM thickness, which is about 1/8". You will need a framework of some kind to support it.
You cut it with regular woodworking tools or with a utility knife.
It comes in 4' by 8' sheets, so you probably won't need to glue it, but if you do, crazy glue works well. I have also had good luck gluing it together with foam to foam contact adhesive like K-Grip or K-Spray.
Old 08-13-2011, 08:41 AM
Trunk Upholstery
What do you generally use to make up the framework in the trunk?
Old 08-15-2011, 11:07 AM
Wiki Edits: 22
You can use plywood, metal, regular wood. Anything to hold the panels in the place you want them.
upholstery 58darlene Interior 3 12-17-2007 07:27 AM
upholstery carlmelton Introduce Yourself 2 04-27-2006 07:10 AM
upholstery Morrie1 Interior 1 11-17-2005 05:07 PM
upholstery kit 39 Ply. 1939P7 Interior 1 11-10-2004 08:31 AM
upholstery... vintage Interior 3 07-16-2002 11:14 PM
