I'm replacing the trunk weatherstripping on my '64 Tempest. When applying adhesive do you just put it on the buttom of the channel or do you do all three sides? The stuff I took off appeared to be original and was glued on all 3 sides.
i use alcohol swabs , brush the black window primer you use around windshield before either the ribbon or the caulk type .
this works good and apply the glue to the car in short spurts like two feet at a time ,press rubber seal in place lightly , then pull back and let air dry fort short time and then press in tightly trying not to stretch it .
if your afraid glue will get on car when you pull back to let glue air, just tape area off .
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
