Trust "beaten on" lower control arms or not?
I purchased my 65 GTO some 25 years ago. Back then I didn't have much cash, tools or intellect for that matter. Back in the day, I swapped out the front drum spindles for disc brakes from a 69 Grand Prix. That all worked fine, the troubling part is I removed and installed the lower ball joints without removing the lower control arms. Someone advised me how to do this and it essentially involved knocking the old joints out and with the ball joint stuck in the hole I jacked the car up from below the ball joint and smacked the control arm around the ball joint with a hand sledge. I actually worked to install the ball joint. Each impact with the hammer caused the ball joint to inch in a fraction.
Now fast forward 25 years and now we've got the neat little tools that can press lower ball joints in, and you can even rent them from Autozone. But I'm wondering if I should trust the old lower arms that I wailed on so much. The poor A arms show all the impressions from the hammer blows by a determined 20 year old. The car was driven many a mile after this delicate procedure with no problems. But I have vivid memories of a 69 Chevelle I was riding in once thats lower arm cracked and released the lower ball joint, just because we popped the brakes on after running in reverse and turning. An those weren't wailed on.
So would you trust them as is? Thinking the impacts wouldn't degrade them significantly.
Or buy old ones from another car? Like I said I've seen stock ones fail for no good reason
Or go after market? Someone probably makes new lower arms for them. Of course they might be cheap Asian ones too.
