Truth or Myth - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-13-2008, 12:05 PM
Originally Posted by Tomard
Thanks for that explanation, it was actually very cool, as your synopsis was close to what my little brain thought was the world .....
And the documentation that you do, I was a little overwhelmed, as it was my first attempt at a major motor, transmission & rear end rebuild, so I was learning as I went along, being careful and methodically keeping parts straight
Now, if I would have checked more (that I will forever on), I wouldn't even be changing this head gasket, but for someone that didn't know JACK, I am pretty pleased I have my 1980 smogger 350 sbc up and running well, with new Alum heads, cam, intake, carb, exhaust, removed all the smog stuff, rebuilt a 200r4 tranny & a working 3.73 rear end (was a 3.08).
I don't even know my quench, which really sucks .... as now I want to get more technical and squeeze every bit out HP/TQ out of it, but kind of hard when you are just guestimating CR!! Which by the way was 8.2:1 stock .... so I think I am up around 8.9:1 or there abouts, but don't know deck or exact bore size, YET!
I hear ya, on loosing track of taking dimensions. There always a rush to get it together to hear it run combined with an assumption that the machine shop and the parts all work together. Slowing down and keeping track of everything is just something you learn as you go, often the hard and expensive way.
Tight quench is more an insurance policy against detonation as it is a power generator. It does add some power but probably is more significant in that it helps prevent the loss of power to detonation. Detonation in and of itself can be more costly than lost power as it has the potential to hammer the engine to pieces. It's effect can be seen in rod bearings where its forces blow the oil out damaging or failing the bearing and journal. It certainly can be seen in piston and ring damage which will vary from heat failures where the piston is burnt thru the ring pack and or galling of the skirt to the cylinder wall, or holes literally blasted thru the piston crown.
The other thing a tight quench does is improve fuel economy, the extreme turbulence produced does an excellent job of breaking up fuel droplets and mixing them with the available air in the chamber. This mixing and turbulence insures that the available fuel is consumed and the the flame front burns faster increasing the early pressure and temperature rise in the cylinder. The first 90 degrees of movement after TDC firing is the most effective for producing power. So getting the burn over early and quickly adds a lot of efficiency to the engine.
Bogie
Cutting glass by sandblasting, Urban Myth? MARTINSR Body - Exterior 61 01-03-2015 09:48 PM
Stud Girdles - Myth or Legend??? hotrodf1 Engine 3 10-16-2007 11:24 AM
5.7 Vortec Casting #s Myth 062 & 906 Mustangsaly Engine 6 12-27-2005 07:19 PM
What Temp Thermostat and Urban Myth? erichb Engine 4 12-03-2004 12:09 AM
Welding tale truth or fiction? 302 Z28 General Rodding Tech 26 02-29-2004 07:23 PM
