trw camshaft tm109 sbf - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 09:18 AM
Does any one have access to an old trw performance cam catalog.Need to know cam specs on tm109 trw cam (sbf).THANKS
Old 04-17-2012, 09:20 PM
Got a degree wheel?! ...dial indicator?
6sally6
Old 04-18-2012, 10:50 AM
There is a TP109 TRW performance camshaft for the SBF. It's a mechancal lifter camshaft. Recommended valve lash is .020" hot, on both intake and exhaust. Cam lobe lift is .330", for a gross valve lift of .528" with the standard 1.6"1 ratio rocker arms. Lobe separation is 107 degrees. The duration at at .050" tappet lift is 251 degrees intake, 252 degrees exhaust. Cam timing at .050" is: intake opens 23 degrees BTDC, intake closes 48 degrees ABDC, exhaust opens 58 degrees BBDC, exhaust closes 14 degrees ATDC. Regards, Chase
old trw camshaft sbf tm109 solid lifter jeyates General Rodding Tech 0 03-31-2012 10:38 AM
What camshaft to use dwatep Engine 1 07-17-2007 03:59 PM
What camshaft for me? orn Engine 4 06-17-2007 11:35 AM
Camshaft I.d. ?? CHEVY NUT Engine 2 05-17-2007 04:49 PM
Camshaft LSA? KeithB123 Engine 4 03-15-2004 08:31 PM
