try figuring this one. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2011, 04:02 PM
I run a shop out of arkansas and have a problem with a 97 chevy tahoe 5.7 lt. Problem is, it is knocking but didnt prior to having the entire intake replace by one of my guys. only reason for replacing intake was because he broke one of the coolant ports off. There is no antifreeze or anything else like that in the oil. Im not sure if he did something wrong which caused this and he is just trying to cover it up or what. Ive checked the oil pump driver and seemed fine. if anyone has ever seen this or has any other ideas please let me know. Thanks.
Old 05-16-2011, 05:01 PM
T-bucket23's Avatar
Wiki Edits: 26
Did he use one of those brown disks to clean the intake surfaces. If he did and any of it got into the engine, it will wipe the bearings.
Chet
Old 05-16-2011, 05:16 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
My last work truck was a 04 Chevy with the 5.3. On some occasions it would knock like crazy on start up, at other times no noise.
Old 05-16-2011, 05:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would do an oil and filter change and cross my fingers if it's a bearing noise- which should be determined as best as possible. I've had good results listening w/a stethoscope to isolate the location of the noise- it may not be bearings.
Old 05-16-2011, 05:31 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 on the oil change, I have seen this before also and if it wasen't a bearing it was the oil-pump. JMO
Cole
Old 05-16-2011, 06:26 PM
Semper Gumby
Wiki Edits: 2
knocking
Is there just enough of an intake air leak to make one or two cyl run lean and detonate?
Old 05-16-2011, 06:57 PM
willowbilly3's Avatar
Last journal entry: Body mods
I'm thinking he dropped something down the intake which imbedded in the top of the piston.
Old 05-16-2011, 07:09 PM
eloc431962's Avatar
Wiki Edits: 37
That is a very good possibility, good call on that.
Cole
Old 05-16-2011, 07:33 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Could be timing related. That one should be set at 0 degrees, and electronically adjusted with a scan tool. The engine rpm needs to be raised/goosed above 2000-2500 rpm, then let idle, for each distributor movement/timing adjustment, until it is set at 0 degrees timing (on the scan tool).
Hope this helps.
Stephen
Old 05-17-2011, 07:21 AM
hmmmmmmmmmmmmmmmmmm
Thanks for the replys guys. Im 100% on the rod noise as it sounds likes it gonna come through the side of the block. Regarding the brown sanding discs, Ive never heard of these causing problems as long as u cleaned up afterwards and we do use these little 2" discs regularly. However, I will probably find something else to use then since I don't wanna take any chances. It is a very big possibility that he could have dropped something in the motor or left something in there like rags or something like that. It wouldnt surprise me it the intake isnt sealed very good as he seems inexperienced with this kind of procedure but its not a spark knock or detonation. Timing was a couple of teeth off which has been corrected. This guy is no longer working for me since he was caught using drugs in the bathroom which explained the numerous trips to the bathroom ha ha. I figure the motor is pretty much trashed so I dont think Im gonna tear it back down since time is money and since I have to provide a new motor anyways(about 1200).
Old 05-17-2011, 07:53 AM
T-bucket23's Avatar
Wiki Edits: 26
I have seen several cases of engine failure after cleaning with the brown scotch brite looking disks
Chet
Old 05-17-2011, 07:58 AM
but?
How did u realize the discs was the cause of youre engine failures? Did u tear one down and find sediment on the bearings and oil passages? Just curious
Old 05-17-2011, 09:03 AM
T-bucket23's Avatar
Wiki Edits: 26
Sent oil out to be evaluated. All instances found silicates (abrasives) in the oil. These were not jobs we originally did. We saw them after intakes had been done and original shop said it could not be anything they did.
Chet
Old 05-17-2011, 09:11 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not arguing w/anyone, but it would seem to me that the particles that are large enough for the filter medium to filter out should leave only particles small enough to easily pass through the oil clearances of the bearings.
Old 05-17-2011, 09:54 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
All it takes is real fine particles like a polishing rouge to wipe out a set of bearings. You can't see them or feel them but they will show up in an oil analysis..
Sam
figuring out compression ratio dman16 Engine 14 03-10-2009 04:34 PM
Figuring out what springs to use Blackhauk90 Suspension - Brakes - Steering 3 07-07-2008 08:27 PM
Help figuring out where I'm at........ Trans Am Tony Engine 2 06-16-2007 11:03 AM
Figuring Air Compresssor CFM JamieK Garage - Tools 3 04-11-2006 01:08 PM
need help with figuring HP and torque shylow Engine 2 01-30-2003 11:50 PM
