Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trying to build a 357
Old 06-29-2010, 08:31 PM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by Newbie3191
Im new to building performance motors so i was looking for help from anyone who can give me pointers on how to get the best but not too expensive parts but i want all input on the project. I was going to build a 383 stroker but when i broke down the motor it already was bored over 40 so i guess i will stick with the 357 all input will be appreciated
Why not make a 385? All a "383" is is a .030" 350 block with a 3.75" stroke. All you have to do is put the 3.75" stroke crank in your .040" block. That will yield a displacement of 385ci. Summit has rotating assemblies that come balanced and include rings, bearings, rods, pistons, and crank. That is the best way to do it if you are just starting out. Consider this and let us know. Also let us know about what block you have. Like if its a 2pc or 1 pc rear main seal. Also the casting number will be helpful. It is located on the driver side bellhousing.
