Trying to decide on a direction - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2010, 07:25 AM
I am new to this, so bear with me. I have acquired a 40 Chevy Special Deluxe and am trying to decide what direction would be the best and easiest way to go. It is a solid car with minimal rust, still sitting on its original frame. I do know that I will be streetrodding it but am not sure where to start. Should I consider using the frame and subframing it or would it make sense to consider maybe an S-10 frame? Which would be better? I can go either way as the parts are easy to obtain. I don't much welding experience so any help would be appreciated. I do know that I will be going with a SBC and 350 automatic. Budget is also another consideration. Here is a photo of what I am starting with. As I start moving forward, I will post some photos of my progress. Any help or suggestions will be greatly appreciated!
Old 05-10-2010, 05:29 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
a mustang 2 crossmember and suspension, from a well known manufacture is a pretty easy install on to your stock frame
(if you can get a buddy to weld it for you if you are not able)
can't decide between BBF or SBF stroker slow'n'steady Hotrodding Basics 10 01-01-2010 02:15 PM
IR T-30 Pump Rotation Direction? blsnelling Garage - Tools 4 11-02-2007 03:38 PM
Please advise shock eye mounting direction bartamos Suspension - Brakes - Steering 5 09-20-2005 10:48 AM
Radiator flow direction cboy Engine 6 10-07-2004 09:43 AM
decide my paint job. crazy larry Hotrodders' Lounge 13 01-22-2004 12:22 PM
