Trying figure out what engine to buy - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2013, 05:22 PM
I have a 73 mach1 and I'm thinking about putting in a newer motor with a computer so ill have the chips put in r should I just stick to a 429 that I have
Old 03-13-2013, 05:32 PM
Banned
Keep the 429 please!
The Following User Says Thank You to killeratrod For This Useful Post:
LATECH (03-14-2013)
Old 03-13-2013, 05:38 PM
Put a new Coyote in it
Old 03-14-2013, 09:13 AM
Well the 429 has aftermarket cam dove heads stainless still valves rocker arms and a **** load of polished aluminum parts on it for $1500 is it a good buy because its just a regular 429
Old 03-14-2013, 11:34 AM
A "regular" 429 is a GREAT engine. What do you need a "chip" for? A '73 has zero computer components, and they're not needed. The electronics are nice and all, but "necessary" for the modern "little" engines to "keep up" with a "regular" 429...
For clarity, they're not "dove" heads. They are "D0VE" That is, "D zero VE". D = 1970s era. 0 means 1970 casting. VE means multi-use (cars, pickups, etc.).
You don't need a Cobra Jet to make power. Also, a 460 crank, rods and pistons make it a 460 (same bore size). A 501 is a crank grind away...
BTW, the "flat back" is my favortie of the Mustangs...
FWIW
Jim
The Following User Says Thank You to Mr. P-Body For This Useful Post:
LATECH (03-14-2013)
Old 03-14-2013, 12:01 PM
Banned
you must not have a clue as to what the "electronics" actually do.
They are not for power but for engine management and do one hell of a lot better job than a carb with a mechanical distributor.
Old 03-14-2013, 02:46 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
A chevy engine in a FORD MACH 1 .
Man if you have a 429 mustang KEEP IT THAT WAY.
With some tuning you can make it run with a carb and a non electronic dizzy.
If you want to go EFI you can go to one of the aftermarket EFI setups and an electronic dizzy with computed timing .
Putting a 350 chevy in it would be DE TUNING IT.
Fact is stranger than Fiction
Old 03-14-2013, 03:23 PM
delawarebill's Avatar
mustang
if that 429 is factory in your car ??? do not replace it...
even if not i still keep it..
Old 03-14-2013, 04:02 PM
Thanks for the info I was just asking I don't have any for guys to ask local. And I would never put a Chevy in a mach1 that's just stupid .dont think I don't like Chevy I drive a 64 step side as a daily driver , I love both of them. Again thank I'm going tomorrow to pickup the 429
Old 03-14-2013, 04:03 PM
I mean ford
Old 03-14-2013, 04:17 PM
I found another 429 for $500 he said it runs but can I trust him ??????????
Old 03-14-2013, 04:25 PM
Banned
If you want a fun car for not a lot of money I would drop at 3:02 with T5 in it.
Old 03-14-2013, 04:54 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
The 429 is not exactly a cheap motor to build up, it will cost $$$ compared to just about all other choices but it would be the choice for that car yes.
And the closest thing chevy that you should install is the factory Qjet carb that came on some of the cobra jets of the day. Qjet on a ford no kidding.
Old 03-16-2013, 03:10 PM
LATECH's Avatar
Originally Posted by hcompton View Post
But lots of fast mustangs have chevy motors. Just one trip to the drag strip you can see at least 3 of them. Many over 500 hp. Not a cheap number to hit with older fords.
I would have to agree. I see bowtie powered ponies on passtime every week. I guess there are a lot of chevy small blocks out there and not enough cars to put em in.
They do make some serious power.......I have seen falcons done that way too.
I guess the weight factor plays big there.
I have seen some fox body mustangs with 347 strokers ( FSB) in them and they run real good. Its about time the aftermarket levels the playing field for ford. And chrysler . JMO
i am trying to figure out what my engine came out of help please!! Danny1986 Hotrodding Basics 7 02-16-2011 07:14 PM
Engine trouble- can't figure out a problem. vintagegirl Engine 3 09-08-2009 06:34 AM
Engine skipping can't figure it out Tubbed71 Engine 14 08-16-2009 05:59 PM
which engine should i buy? snids53 Engine 11 09-16-2008 04:31 AM
Buy new engine? steveyb4342 Engine 6 05-01-2007 02:34 PM
