trying to figure out what gears I need - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-01-2011, 06:18 PM
sqzbox's Avatar
My pipes are my music
Originally Posted by inquiring_mind2
sqz what part of Indiana are you from
20 mi. N. of Evansville In. Bog's I run are in Oaklnd city In. 30 mi. S of here is Henderson Ky. that has two events a year but they are realy soupy and I've seen a few engines puke from water injestion including my buddy's 396 that is raised 10 in. plus 34" tires.
  #32 (permalink)
Old 02-26-2011, 05:26 PM
inquiring_mind2's Avatar
a shade tree mechanic
ok so I have called everyone that I can think of and all the ones people have recommended and no one can tell me what gears I need to run they all say they need mile per hr to figure it out. Well as most people would know in the mud we don't need to know how fast we are going. So if anyone out there knows how to figure it out with out having to know the mile per hr would you PLEASE let me know thanks
  #33 (permalink)
Old 02-26-2011, 05:52 PM
ericnova72's Avatar
More for Less Racer
You my friend are in "Trial by Error" land.
You'll need to pick a gear ratio and try it out, if it isn't enough or is too much you simply buy more gears and do it again. I know this isn't what you want to hear, but is realistically the only way. There is a lot of that going on in 4x4 circles, my cousin uses a Quickchange rear axle in his mudracer just for that reason. If the track is tacky and he can't get wheel speed he just changes to a higher ratio in the rear. He runs different diameter tires on both ends(like 6" smaller on the front) and different gear ratios on both ends, and then just slightly adjusts the rear with the Quickchange to fine tune it. The smaller front tires are geared to be always spinning a lot faster, to keep them cleaned out and pulling the front straight ahead, and the rears are then geared to closely match the pit "suction" that day with the QC gears.
Reason you can't just easily figure this out mathematically is in your case you have to have the tires spinning, not hooked like they would be on pavement, and since you are in a gooey sticky mud pit that weighs things down and are spinning big heavy tires(by racing standards) it is often HP vs RPM vs Gearing vs Tire Speed to get the wheel speed at a point you can maintain it and not get bogged down.
In this case I would say it is better to have too much gear than not enough, I would think a 4.88 front/5.13 rear might be a good place to start.
8.5 10 bolt spider gears Hubes Transmission - Rearend 1 07-02-2008 04:38 PM
Changing rear end gears? Cutlass403 Transmission - Rearend 8 10-05-2007 01:11 PM
What speedometer gears do I have? Johnny Bravo Transmission - Rearend 3 04-11-2007 09:19 PM
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 05:47 PM
Exploded spider gears...? (12 bolt GM) Bumpstick Transmission - Rearend 7 10-07-2003 06:00 PM
