yes that is right I would love to go to high range but I don't know what gears would go good with the turbo 350 and the dana 300 transfer case I have or I can stay in the low range and use different gears to get the most out of my motor. I am open for any options right now
http://www.rockcrawler.com/techrepor...omax/index.asp
From what I read here^^, low-gear in a Dana-300 is 2.62:1? Assuming high gear is 1:1, if you add 2.62 to your 4.10, will give you a final ratio of 6.72...which is what you'll need in the axles to get the same performance you're getting now...but running in high gear. Gears in the 6+ range is pretty high (low). What about changing to a higher stall converter to get your RPM up (was it 7000 you wanted?). That's definitely cheaper. |
I would like to be able to run around the 7000 rpm range. The stall I am using know is small its 3200. I know I need a bigger one but I understand what you are saying. So If I understand correctly I need something in the 6's to make it work correctly in high. Now will running it in high gear get me more wheel speed? with those gears?? I don't know if it would be cheaper to buy the gears or the converter. A good converter will set me back about 600 to 800 dollars.
Running a 6.72 gear (or something close), in Drive, with T-case in high...will get you pretty much the same performance as as your 4.10, 2nd-gear, with T-case in low. That's a lot of gear though...to get the same performance. Do they even make a gear that size for a Dana 44?
ok I have another question to ask?? I was thinking about running high side on the transfer case and running maybe 1st or 2nd gear in the transmission. I also did some checking around the and tallest gear I can get for a Danna 44 is a 589. I didn't know if that would work or not. ALso would any one be willing to tell me how to figure all of this out?? I am always wanting to learn new things that way I can help others out
i would stick with low range in the transfer case
one thing to think about, is using a little higher gear ratio in the front axle so it will pull you straight |
are only using 2nd now? |
Keep this in mind too. When you go to something like the 5.89 the pinion gear head is getting very small, and much weaker. With the tires you are running you are putting a lot of strain on the drivetrain.
What connecting rods do you have in that 427? Just because your cam is good to 7200 RPMs doesn't mean that the rest of your engine is. I've built a lot of big block Chevy engines and they have very heavy parts in them. The 3/8 rod bolts have a big job trying to keep everything together with those heavy rods and pistons, and the valve springs have some heavy valves to keep under controll. Be carefull when you spin a big block that fast. |
but in low range, 3rd gear is like first in high range.The secret to full pulls is wheel spin like seeing 70 mph on the speedo all the way through the pit.
Cole |
| 8.5 10 bolt spider gears | Hubes | Transmission - Rearend | 1 | 07-02-2008 04:38 PM |
| Changing rear end gears? | Cutlass403 | Transmission - Rearend | 8 | 10-05-2007 01:11 PM |
| What speedometer gears do I have? | Johnny Bravo | Transmission - Rearend | 3 | 04-11-2007 09:19 PM |
| bbc what gears to run.? | chevelle4542speed | Engine | 5 | 12-07-2006 05:47 PM |
| Exploded spider gears...? (12 bolt GM) | Bumpstick | Transmission - Rearend | 7 | 10-07-2003 06:00 PM |
