Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trying to find a engine that will fit some dimensions
  #30 (permalink)
Old 03-29-2013, 05:47 AM
oldBodyman oldBodyman is offline
" the entire powerplant has to fit inside a 20" box"
boggen, do a goggle search and chase down "Tesla's bladeless turbine", it's the only option small enough to fit and produce the power you need. It can be run as internal combustion OR steam driven. It can be made small enough to fit at each wheel, plumbing them would your task but 100psi would not be a problem.
Good luck with it.
