trying to find a engine that will fit some dimensions - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-31-2013, 07:37 AM
boggen, forget what you have just posted, you're over-complicating, Tesla had this all figured out in the 1920's. The problem then was the materials available were not up to snuff for internal combustion. Everything you posted has been solved, it's a self-contained unit.
Tesla's turbine is super efficient AND can run in both directions, as a power unit or a 'turbo charger', mounting 2 or 3 together will double or triple the HP output. Check the link below.
Have fun with it.
teslaturbine.htm
The Following User Says Thank You to oldBodyman For This Useful Post:
boggen (03-31-2013)
  #32 (permalink)
Old 03-31-2013, 08:49 PM
Have fun with it.
teslaturbine.htm
alright.....
"wave rotor", "disc turbine", "blade less turbine", "micro turbine" are what i have gotten hits with in regards to the "tesla blade less turbine".
3 theories i am seeing...
1st theroy, so many of the first set of discs, are acting like a "centerfug pump" and in that compressing and speeding up the air flow, up into a combustion chamber, as fuel/air explodes in combustion chamber, it is re-routed back down to the rest of the discs. to run a centrifuge pump backwards in a sense.
2nd air comes in at the center, and is compressed and speeds up as it goes out to the outside of the first set of blades. fuel is injected. and "eddy currents" are created. these eddy currents moving much more aburtly and in that finite layer of high pressures are achieved to exploded the air/fuel. and then this mixture is pushed back out the remaining discs. (centrifuge pump running backwards)
3rd pulse detenation, i hope i got correct term, somehow plays a roll in both 1st and 2nd doings above. some go with friction of hot gas (fuel/air explosion) being applied to discs, others... i did not go that far into. i also saw some sort of almost "single disc" setups.
i am ready to pull my hair out, more "free energy" and folks making more out than what there blade less turbines are.... 99% is all steam or external shop size air compressor ran. trying to find a tesla blade less turbine, that is ran directly on combustion of fuels has gave a couple leads but, frankly i am a tad hesitant. mainly due to were combustion happens and how the combustion happens. and can the combustion be relied on and controlled to obtain lower and higher RPMs and same for torque.
in some hybrid car article. the telsa blade less turbine does have something going for it. and that is pure amount of weight over multi discs. and acting like a large flywheel. and allowing for internment combustion, and helps to reduce pulsation effects at the drive shaft.
it does have a bonous... air intake on one side (comes in at the center) and then on other side, exhaust gasses come out the center. reducing need like other engines to route things about.
CFM (cubic feet per minute) of air intake, and exhaust. unloaded and fully loaded, has me concerned.
while i have read statements of "self cooling" and then on some pages needing cooling of combustion area (water jacket) for water/antifreeze mix. the "self cooling" with air alone, puts me on edge as in, massive amounts of air flow goes through the engine.
low compression ratio, also has me concerned. granted i am no engine expert and dealing with air pollution / emissions. statements that i do read, almost makes it sound like, they are using massive amounts of air flowing through the engine. to help reduce PPM (parts per million) of some air pollution. but engine is still producing same or higher amounts of air pollution, per 1 minute of time. maybe i am mis-reading.
links....
Wave Rotor Projects
Additional Links
M. Razi Nalim (personal note, need to contact)
Daniel E. Paxson - Controls and Dynamics Branch Personnel (personal note, need to contact)
Control System Development LLC (NDA (non-disclosure agreement) required to see anything)
TESLA ENGINE BUILDERS ASSOCIATION (i am sick and tired of this website) makes more of turbine than anything, but not seeing much of anything beyond something hooked up to an "shop air compressor) everything else, is someone else's notation. and acting like it is there's, at least that is what i am getting from the website.
http://www.teslaengine.org/images/pump.jpg
http://www.teslaengine.org/images/teba23p4.pdf (volvo 850 concept vehicle "ECC")
Completed Pulse Combustion Turbine by member Luis Mendonca, Phoenix Turbine Builders Club, low cost Tesla turbines (personal note, need to contact)
http://www.capstoneturbine.com/_docs...ENGLISH_LR.pdf (personal note, need to contact)
looks like an actual re-world production of a small scale turbines. that might work out nicely, but all i see are "cabinet" setups. vs just the engine.
(gearturbine or greenturbine (no space)) coming up empty on websites besides notes to it.
ttengines - clean air turbine technology
http://www.theage.com.au/articles/20...298575202.html
PowerPedia:Gas turbine - PESWiki
Directory:Tesla Turbines - PESWiki
Tesla turbine - Wikipedia, the free encyclopedia
at odds with myself. i like it, but, my mind is telling me to walk away from the tesla blade less turbine. or like doings. the "power curve" and overall range of the "power curve" at low and high loads placed on engine. it is not like you can go and "change diameter" of the discs or change spacing of the discs. and you will be placed into this "power curve" that is efficient in one range, but suck every were else.
the ttengines - clean air turbine technology might be worth it. and be able to put clutches between "power units". to turn/on off individual as needed. to change the overall power curve. and try to narrow the point were things are the most efficient, across a wider range of power curves. but even the TT engines compared to others are either making everything single piece or multi piece. and i just do not see it happening for me. do not get me wrong it most likely works, and would work well in certain given situations. but i am needing a wide range power curve and meeting the higher efficiency across that entire range.
man, and then i flip flop back. and then flip flop right on back against blade less turbines... its that whole variable adjustments. and adding extra pieces and splitting things up to obtain that variable adjustments. to obtain that higher efficiency across a wide range power curve.
hhmmssss i keep wanting to apply say a centrifuge water pump or air pump (power curve) to the blade less turbine / disc turbine. and i guess i need to get over that, i am not using a set HP electrical motor, but a variable speed electrical motor. or rather in this case it would be a variable generator for the SSTT (sideways snake train tractor). i am still stuck with disc diameter, and spacing, and if there are any fins between the discs. "i can not change that" once set, i am stuck with that. so there is going to be sudden jumps between throttling up the engine per say to get more RPM's and torque. as air is pulled into more discs and exhaust goes over more discs. there will be a limit of how many discs can be used. to evenly disperse incoming air and dealing with exhaust. this is going to relate to diameter of discs, space between discs, and any fins. and right there your setting yourself into a "power curve" and most likely will need to keep at a certain RPM's / Torque. to obtain efficiency. which will most likely mean speeding up and speeding down the overall engine. and using capacitors / batteries. to offset the pulsation. also issues of sudden need for more electricity and then suddenly not needing any energy, there would most likely be a "time lag" that would need to be dealt with, with capacitors / batteries.
this is not a electrical car and trying to build for range. but for traction and power, and using up a lot of power quickly and continuously. i want something that does not rely on need for a bigger capacitor banks / battery banks for range extension. but rather, quick response in production of electricity, to reduce size of stored energy. i want lots of weight low to the ground. even if it is not suspend weight (weight is below suspension). so while in field, i am pulling parallel to the field as much as possible. ((refering to wheel hub motors and the weight)) also weight low to ground, to help reduce "tipping over".
*rubs chin* it is that whole balancing of electricity being generated, and the blade less turbine. and balancing things out in such a way. that fuel efficiency stays up there. but still staying within the air pollution laws/regs. and dealing with the power curve of the engine, and the coils and permanent magnets of the generator. those power curves for both.... and dealing with storage capacity in capacitors and battery banks. to bridge gap between having to much electric produced and not enough energy produced.
blade less turbines are like (right here as i hold my head at eye level), and then i look at the "free piston linear generator engines", and they are here (as i raise my hand just barely above my head, just touching my hair). it is that variable (extra) that the free pistons give over the blade less. that extra variable of be able to adjust things on the fly and on demand. is what most likely going to work out better for the SSTT (sideways snake train tractor). both technologies are there, but that much variable adjustment. is what going to matter long term. and can be taken advantage of both now and later in the future.
a free piston engine, i can take say this 5 foot long cylinder shape that is say 8 inches in diameter. (honestly have no clue on dimensions) and plug it in. attach a few bolts or pins. and i just got that much more power. the free piston turns into a "power cell" or a battery per say. and ya, eventually it would be that easy and a long term goal to reach. but until then. the benefits of free piston, has me.
do not get me wrong, i am still flip flopping back and forth trying to compare free piston to the blade less, to what my mind is able to comprehend. but to push me over to the blade less. there needs to be something more. that i am most likely not understanding.
*open* have at it, even if it means ripping me a new one.
time to work on paper work.
1990 camaro RS and cant find any headers to fit torquemonster General Rodding Tech 6 05-31-2011 11:01 PM
Where can i find a fan shroud to fit my radiator? Dajerseyrat Engine 4 07-27-2010 07:44 AM
Where can i find dimensions? Modern_twist Suspension - Brakes - Steering 2 11-17-2009 06:35 PM
Where do you find a set of spinner center caps to fit a Buick rim? CrashFarmer2 General Rodding Tech 0 04-24-2006 09:45 AM
How do i find out what seats fit?? '54-Hunter Hotrodders' Lounge 8 04-01-2003 03:11 PM
