trying to get 400 hp out of my 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2009, 01:40 AM
i have a 350 that i am trying to get 400hp out of... i can do most of the work myself i just need help with what combinations i should use too reach my gole of 400hp with a budget of $1800-2200 i dont realy care if i cant drive it to work every day but if i want too i can hit a cruise on the weekend...
if anyone can help im most interested...
Old 08-21-2009, 01:48 AM
techinspector1's Avatar
Wiki Edits: 326
Hi Ray. The main question is....heads. Do you have heads or will you buy heads. If buy, what's your budget?
I have a DynoSim pull on file, 350 bored 0.030", these pistons
http://www.summitracing.com/parts/SUM-17350-30/
garden variety GM 883 heads, Edelbrock Performer RPM intake, 600 cfm carb, 1 5/8" long tube headers and this cam
http://www.compcams.com/Cam_Specs/Ca...x?csid=85&sb=0
Cut the block decks to 9.012" block deck height and use GM 10105117 head gaskets. Makes 380 hp @5000 rpm's and 430 ft/lbs of torque at 4000. Nice, cheap little street motor that will run on pump gas.
Old 08-21-2009, 03:01 PM
sorry about the other post i thought i lost it wen my laptop died on me...
i i have a complete running motor that came out of a boat the bottom end was rebuilt not long ago its like brand new... i do have a set of cast 2.02/1.95 heads edlebrock rpm performer intake and a 600/750 holly carb wit spacer wold this help me... if not what heads would i use for your idea???
Old 08-21-2009, 03:24 PM
i would love too do the most work as i can i want it to be mine... what do u mean vortec could pull them off a camaro firebird suburban if not what kind of cars do the come off im not very good with numbers and castings...
95 s10 exc
Old 08-21-2009, 04:24 PM
what kind of cam should i go with and should i do any thing with the bottom end it is already .30 over and wen i did a com test it had 173-175 on every cylender... i would like to put a 700r4 in it but what i was told it wont hold.
Old 08-21-2009, 04:33 PM
a 95 s10exc that i have put a 373 gear under it
Old 08-21-2009, 05:02 PM
extended cab 2wd i dont have he heads on hand they r at my property...
i live in Michigan we dont have emissions
Old 08-21-2009, 05:25 PM
thanks for all your help it was much help full!!!
Old 09-07-2009, 05:12 PM
Last journal entry: Little Progress, Now i have a plan
good info, this is the direction im planning on going too.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
400 smb wanting to make around 300 - 350 hp 400smb_s10 Engine 5 03-25-2007 04:02 PM
350 or 400 sbc cokeman277296 Engine 19 03-20-2007 07:39 PM
Factory 350 cast crank hp rating KGRIFF Engine 9 03-19-2007 08:41 PM
More HP for my 350? sscamaro_510 Engine 9 04-25-2005 09:22 AM
