Trying to get a answer on springs on dart heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2006, 12:27 AM
tiresmoke55's Avatar
PO-BOYS-TOYS!!
Last journal entry: My new 55 chevy pretty sharp
hey guys..
I bet you guys are just about sick of all my question's about my car this past week lol but sorry i got to ask something again
some of you on here might already read a past post on here that said a guy had a set of used dart heads 4-sale? long story short im thinking about buying them off this guy ok, but im having a little trouble getting some real good info on the style heads he has..... the part number is dart iron 10621122p...... ok here is what i know from jegs site they said 72cc, 205 valve's, straight or angle plug, and there good for 620 lift........ thats good info
BUT WHAT I NEED TO KNOW
the springs on them heads are good to 620max lift they dont say anything about the minimum lift cam you can run with those springs....... I have a 515 lift in the car now and i think the springs on those heads might eat the lobes of my cam????
Don't get me wrong i know i can buy the springs that matches my cam but that gets up in the bucks$$$ u know,,,,,,, and if i had to buy new springs it would be cheaper to just get a brand new set of heads with the springs i need already on them u know and save money.... If the 620 max spring would be ok for my cam it would be a different story...... any info would be great THANKS
Old 09-06-2006, 05:33 AM
Very good questions for your cam grinder.
Old 09-06-2006, 05:40 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
If you're concerned with an issue like that then yes, contact the cam manufacturer. Maybe Dart directly. You can circumvent that concern by buying a set of bare heads and adding the other valvetrain parts yourself and getting the springs the cam manufacturer recommends.
Old 09-06-2006, 11:54 AM
I could be wrong but the "good for lift" will relate more to coil bind than spring pressure and the spring pressure will relate more to the lobe profile of a particular cam than max lift as well as how high you'll be revving her. Just my .02
Old 09-09-2006, 01:15 AM
PO-BOYS-TOYS!!
I do have a set of new complete set of valve springs,retainer's, keepers,ext.. of a new pro 1 dart alum head never ran i do think there a triple spring good for 620/690 lift i got from a friend of mine,,,,
But i dont know if the springs are for a roller cam or hyd? ill sell them very very cheap if some 1 could use them... the heads that was on the part number is #dart 11711143 let me know thanks......
Old 09-09-2006, 08:55 AM
nitro_baller4692's Avatar
floppers forever
tiresmoke55 you need to know what the seat pressure of those springs are also the open at your 515'' lift.you could also if pressure is to high remove the triple spring or inner spring to get what you need.i agree that your probably to high on onen pressure.i ran a 510''lift 280dur solid lift cam and pressures were 165lb. seat and 355lb.open.
just throwing #'s at ya
Dart Iron Eagle or Vortech Heads bigjoedo Engine 31 05-14-2013 05:36 PM
SBC Heads -= AFR - Trickflow - Dart - Brodix =- Delirious2000 Engine 25 04-22-2009 12:58 PM
Why spend money on heads? F-1Rodder Engine 8 03-07-2008 12:09 AM
Whats the best way to store my new Dart heads? batman09 Engine 3 02-13-2005 09:55 PM
Dart Heads markn Engine 2 12-11-2003 04:45 PM
