Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trying to get rid of that annoying check engine light!
Old 01-17-2004, 09:26 AM
adtkart adtkart is offline
Could be any number of things listed. Could also be a bad injector, TPS, or many other things. Have the codes read and go from there.
Don't just keep driving it with the light on or remove the bulb. It is on for a reason. You may end up sitting on the side of the road when it decides it has had enough.
