trying to get rid of that annoying check engine light!
Check engine light on my 89 mustang won't stop flashing... what can be done to get rid of the annoying light?? also what would make the 302 engine a little sluggish on takeoff?? it drops almost to a stall when you hammer the gas but then takes off...
would the egr valve affect this?? Last edited by Munchos90; 01-16-2004 at 08:41 AM. |
catalytic converter?
can be anything as far as the check engine light. but most likely a bad egr sensor. sometimes the o2 sensors go bad and can cause the car to dump fuel . that would make the car stumble off line.
check fuel pressure should be no more than 45 with the vacuum off. on a stock engine and 35 with the vacuum on. give or take 3 psi in either direction. how the rest of the cars tune up?? . |
My guess would be O2 sensor, but to be sure, you need to get the codes read. You can buy a cheap code reader for under $20 for your Ford. A garage will charge you that much just to read it, so you might as well buy one.........invaluable tool in the later models.
Ontario Rodders |
electrical tape, or rip the dash out and smash the bulp
Go to this site http://www.dalidesign.com/hbook/eectest.html and read the instructions on how to do your own EEC test with a test lite and a jumper wire. Instructions on how to read the codes and link to the 2 digit codes included. Could be a number of things. Read the codes first.
uh oh - link doesnt seem to be working for me. Try your search engine for that site or PM me and I will try to email you the info. Last edited by 2-manytoyzs; 01-17-2004 at 12:45 AM. |
getting the coldes read is the proper thing to pinpoint problem. only reason I suggested the EGR passages is tha Ford has had problems in the past with a lot of Carbon buildup in the EGR p****ages causing the Check Engine light to do some crazy things.
Could be any number of things listed. Could also be a bad injector, TPS, or many other things. Have the codes read and go from there.
Don't just keep driving it with the light on or remove the bulb. It is on for a reason. You may end up sitting on the side of the road when it decides it has had enough. |
Get a Haynes book & a cheap analog voltmeter (mine was $5). A couple of jumper wires & you can read your own codes. Might also clean the throttle blade & IAC port if you haven't lately.
