Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Trying to guesstimate HP
  #16 (permalink)
Old 11-20-2012, 01:56 AM
thinwhiteduke's Avatar
thinwhiteduke thinwhiteduke is offline
Living In The Past
Originally Posted by Brian Morency View Post
I'm trying to guesstimate my engines HP
Any guesses? Here's mine, 310HP?
X3 what tech and bogie said...
My guess is nowhere NEAR what horsepower you would get using that camshaft in an engine set up propery for that cam. You will require a static compression ratio of 11:1 , quench at 35 - 40 thou , good flowing aftermarket heads , 750 CFM carby / victor junior, upgraded ignition system, 3500 stall converter , MIMIMUM 3.50:1 gearing( with a 26" tyre ),
Ya can't just chuck a camshaft like that into a 'stock' bottom end and expect that it's gonna be all good, if it was THAT easy, everybody would be doing it!
Duke
