Trying to guesstimate HP - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-20-2012, 01:56 AM
thinwhiteduke's Avatar
Living In The Past
Originally Posted by Brian Morency View Post
I'm trying to guesstimate my engines HP
Any guesses? Here's mine, 310HP?
X3 what tech and bogie said...
My guess is nowhere NEAR what horsepower you would get using that camshaft in an engine set up propery for that cam. You will require a static compression ratio of 11:1 , quench at 35 - 40 thou , good flowing aftermarket heads , 750 CFM carby / victor junior, upgraded ignition system, 3500 stall converter , MIMIMUM 3.50:1 gearing( with a 26" tyre ),
Ya can't just chuck a camshaft like that into a 'stock' bottom end and expect that it's gonna be all good, if it was THAT easy, everybody would be doing it!
Duke
  #17 (permalink)
Old 11-20-2012, 10:52 PM
Brian Morency's Avatar
Hauling Donkeys
Last journal entry: bros car
I'm running pretty good with 1600 converter and 2.73 gears at the roll racing. Taking out 13.2-12.8 cars as is pretty good.
  #18 (permalink)
Old 11-21-2012, 01:27 PM
"Roll Racing"? Does this mean the car has a hard time getting started? What Tech, Bogie and others are telling you is "word". They've all "led the horse to water . . . ", but it seems you keep drinking the kool aid.
Best of luck with your solutions.
Pat
  #19 (permalink)
Old 11-22-2012, 07:12 AM
Hauling Donkeys
I appreciate all the advice. I understand i need larger converter and gears in order to take advantage of the large cam. In just saying it runs strong when in the power band.
guesstimate hp. for me garrell.770 Hotrodding Basics 2 12-15-2011 11:18 PM
Guesstimate HP/TQ for my 388... Blownchevelle68 Engine 1 02-10-2011 06:23 PM
Power guesstimate? v8hed Engine 15 07-30-2008 07:52 AM
Help with guesstimate? BMM Engine 2 10-14-2006 07:54 PM
Guesstimate Pr0blumz Engine 6 05-12-2006 03:56 PM
